MP3 CDs with CD Text
For those who have been struggling to create MP3 CDs with CD Text that displays both CD title and track names, I have found a free program that may interest you.
The program is called Burrrn (yes, that's 3 r's) and if you do a Google search you'll find it at burrrn.net
This program cannot copy CDs (there is no support for .cda files), nor can it manage folders, but if you want a simple MP3 CD to play in your RL, you can simply drag and drop the MP3 files that you want to the interface and click the Burrrn button.
I have now used it successfully many times. If the files you drag and drop have the appropriate tags, the program will automatically add the CD title and track name information. If not, you can manually edit it yourself.
So instead of playing CDs with no titles, I simply copy them to CD RW discs using MP3 files and the RL display shows me everything I need...cool.
Pete
Pete
Originally Posted by Scott in Houston
Does this work with MP3 CD's as well?
Pete
After I posted this question, I did some research. Basically, I was asking if when you burn an MP3 CD, if it would give it a 'title' that shows in the audio screen when you're seeing all 6 of your CD's/DVD's. The default is to show the first MP3 as the disc title.
I wish the RL read the tags for each MP3 and not the file name.
Below are pictures taken from my NAV screen. Note that the CD title is "Dark Side of the Moon" and the first track is named "(i) Speak To Me (ii) Breathe".
Main Audio Display Screen
Track titles
Pete
But that's for an audio CD. If you burn a bunch of MP3's onto a disk, it takes the first MP3 file's name.
Thanks for going to the trouble of taking and posting pics!
The other negative I have found is that the track order isn't correct because it doesn't pre-pend the track names with 01, 02 etc. Not sure if it can do this with the program.
If anyone else has guidance on which CD burners work well when creating discs for our RLs, please post the information. Let us know if the program handles MP3 as well as standard CDs and whether it can correctly label the CD text for the CD title and the tracks. I know that many of us have struggled with this for a long time.
Pete
Originally Posted by petemc
Nope, your going to have to trust me on this, but despite what it says on the NAV screen, I made this from MP3 files. I don't know why it recognizes the disc as a normal CD on the display.
Pete
Pete
Thanks for the info on Burrrn. I downloaded it and tried it yesterday. I'm really happy with the results from burning MP3's. It's so nice to finally see track info (like the pic above). Also, since this was the first time I played MP3's in the RL I was really pleased with the sound quality. Much better than XM.
Originally Posted by Gator5000e
Not sure if this what you're looking for, but the free version of Real Player 10 works great. Just be sure when installing that you choose advanced options so you can avoid the unnecessary junk it tries to install. It will work with mp3, wma, and other files. It will write CDText as well. I've recorded a number of CDs just to get the text on the display. You can also alter most of the text info so you can display what you want.
Oh, well, back to the drawing board
Bobwied, the program has worked every time for me so far. I just wish I could set the track numbers correctly, I am not used to my albums playing the wrong track sequence.
Pete
Pete, with Burrrn, does it only burn them in alphabetical order?
CD burners with the capability to order the tracks do it simply by pre-pending the track names with 01 02 03 etc. so that the alpha-numerical sorting works. If they offer the ability to add CD text for the CD title, it normally comes from the first track name.
Pete
With Burrrn you can place your songs in any order you with. It's simply drag and drop. If you load a whole album you can then go back and rearrange all the songs in any order you wish.
I must admit that I didn't try moving files by dragging them because there was no indication that the program would handle it. I've got to try this.
Thanks for the info.
Pete
Did you guys download the 1.14 beta from burrrn.net? And the executable is the 'burrrn_package.exe'?
This site just doesn't seem like a site to get legit software not containing spam and/or spyware, so I'm just making sure.
InFaMouSLink
11-11-2015 12:19 PM
InFaMouSLink
10-27-2015 06:52 PM
lanechanger
10-13-2015 10:56 AM
