keyless remote, nav,etc
Old Jun 22, 2011 | 11:31 AM
thomasmsmith's Avatar
Need some help. Got back ito my car and tried to start but no luck without using key from remote. Batteries in remote good. Now have to use key to get in car, navigation system, remote door locks, fuel door, etc don't work. Is there a way to reprogram keyless entry etc?
Old Jun 22, 2011 | 02:43 PM
HEAVY_RL's Avatar
Sounds like a dead door handle scenario to me.
info = https://acurazine.com/forums/2g-rl-2005-2012-76/how-program-keyless-remote-695666/
Old Jun 22, 2011 | 05:30 PM
Megatron's Avatar
I think you have to better describe the symptoms. Are you saying that once you get into the car with your key, the nav system doesn't work, power locks don't work, and the fuel door button doesn't work either??? None of that stuff should have anything to do with your remote. If that is the case, it's probably your car battery that's dying.
If it was just the keyless start and the touch handle, it could be your remote. Does your car unlock and lock with the buttons?
Old Jun 23, 2011 | 12:32 PM
oo7spy's Avatar
Instructions for re-syncing your fob are on the back of the fob. However, I have to agree with Megatron that it sounds like your battery is going.
Old Mar 28, 2012 | 04:28 PM
shahram72's Avatar
You can program a keyfob yourself with this car? The car I am getting has only one. There are used ones on ebay, but the listings say the dealer has to program the remote. Is this not the case?
Old Jun 26, 2012 | 01:22 PM
makalif's Avatar
9th Gear
if i buy a key on eBay for '07 RL, how much i am looking to pay to program it? and how do i get the manual key to fit my door handle. can anyone help...
Old Jun 26, 2012 | 01:58 PM
oo7spy's Avatar
You will need a locksmith/key cutter to make the physical key fit. You will need a Dealer's Honda HDS tool to make the remote in the fob work with your car which will be on the order of $100-200.
Old Jun 27, 2012 | 09:35 AM
IanVS's Avatar
No, but you can sync it to the car. Meaning, linking the driver's memory settings (seat, mirrors, wheel) to the key fob.
Old Jun 27, 2012 | 10:32 AM
oo7spy's Avatar
Come to think about it, I recently bought a CR-V from a Mazda dealer and they had an extra key made. You may not need the Honda HDS, but you do need a special tool to program the RFID.
Old Jun 27, 2012 | 10:45 AM
IanVS's Avatar
Correct me if I'm wrong, but I think you need the HDS to allow the engine immobilizer to recognize the chip in the physical key.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
