Incessant synching problems
I cannot get my car to say "driver 1" or "driver 2" (I've tried using both key fobs -- and I've gone through the reset process in the manual about a thousand times). It just says 'welcome'.
The other week I took my car to the dealer. He said the medallions in the fob had gotten off kilter and one of the buttons on the fob was essentially always 'on' (being pressed down). He fixed it....or so I thought.
Today I had my alternator replaced. They didn't replace the battery (and I didn't have to enter my PIN code or anything). Now this INCREDIBLY ANNOYING problem has returned. I've tried both fobs. I even disassembled both fobs and made sure the medallions were aligned properly.
I just want the car to remember my settings when I get in. That's all. I just want that god*amned voice not to come on every time I turn up my AC. I feel like the guy in the Telltale Heart.
http://www.fixya.com/cars/t5130613-2...fob_code_reset
"turn key to on, but do not start, press and hold the lock button for one second, turn key to off position, turn the key on and off three times ending the cycle with the key in the on position,press the lock button,you will hear the door lock cycle, press lock again to set code"
I never even got to the confusing end. I followed it up to "you will hear the door lock cycle" [which I didn't, by the way]. Anyway, something wonderful happened. It now says "driver 1". I hope that voice prompt is dead forever.
I will have to remember this if I ever get into that situation. This sounds as if it is the procedure the dealer would use to link a fob into the car. The car comes with two fobs, but has the memory to use up to 4 fobs according to the manual. It sounds as if this works like a garage door opener. My old garage door opener has a programming cycle to accept up to six remote controls, first in first out basis....you program in a 7th remote, and the first remote is lost.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
