I-015: Nav Audio Volume Low?
This weekend's learning project has been the nav system. While it's the original disc and thus a bit out of date with the new subdivision developments popping up all over the place, it did a reasonable job with the routes I travel every day.
However, I find that at highway speeds the voice prompt volume seems a bit low, and I can't seem to find any way to increase this. It does a fine job reducing the stereo audio automatically when a nav prompt occurs, but the spoken nav voice is still not as loud as I'd like it to be?
Actually, it may not be all that simple. I was having NAV volume issues in that regardless of the volume setting, it was so low I could barely hear it give directions. HERE'S my original post about it.
Turned out to be a problem with the unit which was replaced under warranty. Good news was that when I got it back, it had the new Navi updated disk in it.
But then again, maybe you just need to turn up the volume!
LL
LL
Yeah, I knew about the volume setting in the nav main setup screen, but I was wondering if there is a way to adjust the volume during the prompts of an actual nav routing - when I tried hitting the steering wheel volume while the nav is speaking, it seemed to have no effect. I didn't try the headunit control though, just the steering wheel volume up button.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
