HFL system does not recognize"security"
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I recently paired a Blue Tooth phone without issue.
In the original system setup I indicated to use a 4 digit security code. I then read in the owners manual that the security can be turned on/off by using the voice command
"Security" when pressing the talk button for the HFL. The system in my RL does not recognize the word security. The only way I can change using the security code is to go thru the entire system setup. Not a big deal.
Any one else try the security on/off procedure? Does it work for you?
Originally Posted by vp911
Moved to bluetooth subforum.
I didn't even know there was a security feature, so I can't really help. Sorry!
Originally Posted by medrxman
The problem is not only Blue Tooth related.
This can be useful for, say, a BT printer or an open bluetooth network link... but since this is usually wholly irrelevant with a hands-free link (i.e., they really have to be paired to be used) and there's no other info transmitted over the BT link in the car (except if you can get your AcuraLink to work through your BT phone, and even then it's not personal information... and most people's don't work anyway...) besides the voice information when you talk... security on your BT connection isn't going to matter.
Unless for some reason you want to disable using a code when you link your HFL...? Can't see why you'd want to do this....
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
