HF Link Stuck
HF Link Stuck
Any suggestions on how to fix this issue. I dont know what happend it all the sudden activated my HF link system and I cant get my radio, XM, or audio to work unless I hold down the back button...
Please help!!
RLguy05
Please help!!
RLguy05
Yeah I tried that ... and it still is not releasing my HL link.. GRRR i have the battery cables off the car in my gargage hoping that it will reset itself.
If you decide to check the unit, remove the glove box instead of trying from the passenger kick panel. It's much easier to remove/replace that way. The glove box is fairly easy when you know how.
is there a reset button on the unit itself...I am not sure what the unit looks like I am trying to find diagram, or some information about the unit. You have any suggestions?
There is no button. I just thought you could unplug it and plug it back in. It is about the size of a cigarette pack attached by a green 12? pin connector. If you take out the glove box it is mounted to vertically to a bit of aluminum frame by two 10mm nuts. I found it by referencing this page http://www.mediafire.com/?k8jqxt8q6t7yq and the "Electrical component locator" file. If you find it you could unplug it to see if you get your radio back. You cant use any voice activation features with it unplugged however.
HEAVY_RL (09-17-2012)
I think I've figured out how to post the photo now. This is my old broken one. The plastic tabs for mounting the box were broken off as if someone who doesn't know what they're doing was trying to replace it.
lanechanger
10-13-2015 10:56 AM
