Heres some info on NavTool
For the 2005 Acura RL if you want to install the reverse camerea here is the link on the NavTool that i located on yahoo.
http://www.tvandnav.com/index.asp?Pa...PROD&ProdID=14
Did anyone install this and is $350.00 a good price, also do i have to pull out the front Nav to install this? Any help is greatly appreciated.
Thanks for the info, where can i locate the "group buy" sorry im new to this forum.
i did get the installation guide.
2004-2007 ACURA RL INSTALLATION MANUAL
12 Volt plug (two black wires one with a silver stripe)
Plug and Play harness
Before you begin the installation please become familiar with the products included in your package and the space you will be working in.
First off you must locate the navigation DVD-ROM in the Acura RL. The navigation DVD-rom is located in the trunk on bottom right corner. The navigation DVD-rom will have five unique plugs behind the unit. Please look for two black plugs.
Unplug the bigger 20 pin black connector and insert the plug into the plug and play harness, insert the other end of the plug play harness into the navigation DVD-ROM replacing the original plug.
The next step will require finding accessory power. Accessory power in the RL is found in the smaller 8pin black connector. PLEASE TEST THE FOLLOWING – usually accessory power is the white wire with red stripe(could also be white wire black stripe). BEFORE MAKING the connection test to make sure the wire has accessory power. Connect the black wire with silver stripes found on the 12 volt connector to accessory power.
Connect the other solid black wire on the 12volt connector to ground. The ground wire can be found in the same 8pin connector, usually the wire is solid black.
Please insert the 12volt plug into the unit to make sure the red light comes on. If light comes on turn the vehicle off and connect the plug and play harness to the Navtool unit.
If you are connecting a back-up camera insert the RCA wire into Video 2 and connect the blue wire found on the Navtool unit to the reverse input also found on the small black 8 pin connector usually green/black.
Connect green wire found on the Navtool unit to the handbrake and 2 white wires to ground. All three wires needed to be grounded in order for Video 1 to be activated.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
navtool.com
Sep 25, 2015 05:15 PM
