Help! ...Razr Cingular pair with HF
Old Jan 18, 2006 | 11:18 PM
feeenux's Avatar
Help! I'm having a helluva time pairing my Cingular Razr (the black one from Best Buys...$39...cheap!) with the hands free bluetooth in my car.
Has anybody done this successfully? Would anybody want to step me through the process? Damn, I thought I was pretty good at this stuff, but I can't seem to make this work. I've followed the directions in the manual, but so far...nothin'...can I be losing my touch?!? ha.
Thanks!
Mark
Old Jan 20, 2006 | 06:19 PM
bluemule's Avatar
Thanks!
Mark
If you are still having trouble, you might repost what you are having trouble with...this is a very helpful site, and someone's bound to be able to help out. It's been awhile since I paired my Razr, so I'd have to get out the manual myself.
CAVEAT to anyone else reading this post who may have connected to the Acura Server with settings other than the defaults: After taking my RL in for a couple of scheduled oil changes and having some TSB's done, my settings to connect to Acuralink were gone and the car had been reset to the defaults...I had to reprogram the RL to connect with the Acura Server.
Old Jan 20, 2006 | 08:03 PM
CGTSX2004's Avatar
Thanks!
Mark
Turn car to ON position.
Hit button and say "Phone Setup"
Hit button and say "Pair"
Listen to prompt while activating bluetooth on phone
Hit button and speak 4-digit confirmation code
Select "Handsfree" from bluetooth menu on phone
Select "Look for Devices" on the phone
Wait for search to finish
Enter the 4-digit confirmation code from earlier
Phone should now be paired
Any questions? Just ask.
Old Jan 21, 2006 | 07:08 AM
Dr. E in TN's Avatar
Dr. E in TN
As an addition make sure you keep it simple with your 4-digit confirmation code. I believe it's 0000 or 0001. This should work right away. Prior to doing this make sure you go into the bluetooth settings of your phone and turn bluetooth on.
Old Jan 21, 2006 | 02:00 PM
feeenux's Avatar
Thanks...
Thanks to both of you...I'll give it a go in a minute. This forum is the best.
Old Jan 21, 2006 | 05:09 PM
bluemule's Avatar
Thanks!
Mark
Make sure the Razr is configured to search for a bluetooth connection...that setting can be disabled. There's an "auto Handsfree" setting in "car settings", which is "on" for my phone. Also, under "settings", there is a menu for "Bluetooth link" and everything in there should be configured to search for connection...in case the phone isn't searching for a connection, there is a menu for "find me".
ExcelerateRep
Oct 14, 2015 08:20 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
ivan06106
Sep 26, 2015 04:38 PM
rboller
Sep 23, 2015 02:49 PM
pplcrew
Sep 15, 2015 05:22 PM
