Heavy_RL gets new LEDs
Old Apr 9, 2010 | 02:24 PM
HEAVY_RL's Avatar
I recently ordered License plate and door panel LEDs from http://www.hobbyemporia.ecrater.com/
The order was placed on the 6th, shipped on the 7th, and received on the 9th. Great turn around.
These are the 6 LED pads for the plate lites
These are the 24 LED pads for the doors
Old Apr 9, 2010 | 02:29 PM
HEAVY_RL's Avatar
Installation for the doors was pretty straight forward, here is before:
Hooked the pad to the correct base
Popped off the lens cover with a small flat head screw driver and installed the light base
Pulled the provided 3m backing tape off
and pressed the light into the hole, the tape adheres to the base keeping the light straight.
Old Apr 9, 2010 | 02:30 PM
HEAVY_RL's Avatar
Here are the light tests
And the final look
Old Apr 9, 2010 | 02:36 PM
HEAVY_RL's Avatar
Now for the plate lights... I have seen a lot of people breaking clips and parts trying to get these done.
It took me two minutes with no special tools.
I reached in and popped these clips loose with my hands... there are 4 across the edge
The pulled the carpet back and reached in to grab the light
It was a simple twist and the light came right out. Here it is unplugged from the pig tail.
Again I found the correct wedge base and hooked the new LED up
I taped the wires together and used the provided 3M tape to stick the board flat onto the plug
Stuck the bulb back in maneuvering the board into the hole and viola..
This took me 10 mins top from start to finish and looks fantastic!
Old Apr 9, 2010 | 02:39 PM
HEAVY_RL's Avatar
The door lights are WAY brighter than stock, I cannot wait to see them at night.
The 6 LED pad for the plate lites was the right choice for me as its the same brightness as stock just an arctic white.
Thanks KB1Spec for referring me to www.hobbyemporia.ecrater.com/
Old Apr 9, 2010 | 02:51 PM
KB1Spec's Avatar
Thank you again Greg! Hope everything came out great!
Old Apr 11, 2010 | 11:52 AM
sahan23's Avatar
Looks really good! Nice Job. And all in a matter of minutes.
Old Apr 11, 2010 | 05:38 PM
racerrl's Avatar
2005 RL
Thanks for the great photos Heavy RL. The adapters and led panels look like they are very easy to install. Are they universal as far as being used for the dome light application also?
Old Apr 11, 2010 | 07:07 PM
HEAVY_RL's Avatar
Thanks, glad I could give back to the site.
Yes the package you receive with these are universal for all wedge and festoon (tube) bulbs
You just have to decided what brightness, i.e. number of LEDs, you want.
Old Apr 12, 2010 | 02:39 AM
sleepinxlionhart's Avatar
Can we get some night pics? I was thinking of using the 360 degree, 5 SMT LEDS for the door and license plate light. The 24 LED pad looks super bright though.
Old Apr 12, 2010 | 04:52 AM
Blazing GT's Avatar
that looks super bright. Makes me want to get them mmmm
Old Apr 12, 2010 | 07:24 AM
HEAVY_RL's Avatar
Yeah no doubt... I'll shoot some tonight.
Old Apr 12, 2010 | 09:37 AM
Chas2's Avatar
If these are the ones that have 1 LED on the end, and then 4 on each of side
http://www.v-leds.com/Exterior-LED/C...78377-1-2.html
you may be unhappy with these as not bright enough. You need most of the light downwards and not spread around. Of course you won't fit that 24 LED pad in the space for the license plate lights. The 6 LED pad he used looks good.
The other I found is this 2Watt version
http://www.v-leds.com/Interior-LED/D...87987-1-2.html
Not necessarily advocating the vendor, just that they have a good site so you can find different products easily....
Old Apr 12, 2010 | 10:05 AM
sahan23's Avatar
I've bought the older style LED (194) wedge bulbs from v-leds.com and they worked well for my '04 MDX. But the ones Chas2 is talking about are way brighter! Nice post bro.
Old Apr 12, 2010 | 12:15 PM
SnoWRL's Avatar
Got the LEDs in this weekend they look great! now i am getting some bulbs for the doors next.
Old Apr 12, 2010 | 06:20 PM
HEAVY_RL's Avatar
Ok these are BlackBerry pics in my garage...
Old Apr 13, 2010 | 09:20 PM
SnoWRL's Avatar
Is changing the reverse lights any more difficult than this or just as easy? Im thinking of ordering some reverse LEDs and all the door ones at once
Old Apr 13, 2010 | 09:41 PM
HEAVY_RL's Avatar
I didnt pull the side panels down in the trunk, but I can only imagine that is just as easy.
Old Apr 14, 2010 | 11:11 AM
Chas2's Avatar
Use the cargo net installation instructions if you need to remove the side panels in the trunk. The instructions are in the Garage thread.
Old Apr 14, 2010 | 12:04 PM
I actually have those 360 ones for the license plate lights for my Insight, and I think they work really well. It really lights up the floor and the license plate area like never before. Yup, vleds is were I got them, they're a good vender,
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
eastcoastguy
Sep 23, 2015 06:29 AM
