Galaxy S4 update and bluetooth fails
Old Oct 7, 2014 | 09:12 PM
acurod's Avatar
Got an update from Android 4.4.1 to 4.4.2 and now I can't seem to get the bluetooth to work in my 05 RL. Older os worked just fine. Now I can pair the phone, but as soon as I make the call using the car's bluetooth the call gets dropped from the car and continues on the phone.
Anyone have any ideas?
Thanks.
Rod
Old Oct 8, 2014 | 06:54 AM
HEAVY_RL's Avatar
can you click the headset button and reconnect?
Old Oct 8, 2014 | 07:32 AM
acurod's Avatar
hi Heavy-
no headset involved- the phone pairs well with the car, i can see the signal strength and battery state of charge icons on the dash. but once i make a call using the cars buttons on the steering wheel the call is initiated, i hear the number ringing through the cars bluetooth, and within a second or two the call is dropped from the cars bluetooth but remains active on the phone itself. I have this problem with the phone on my 05 RL and on my 2013 MDX. Before this 4.4.2 upgrade both cars worked fine with the S4. I'm mystified!
Rod
Old Oct 8, 2014 | 09:53 AM
HEAVY_RL's Avatar
right... but there is a button labeled "headset" on the phone... if you press it, does it reconnect?
Old Oct 8, 2014 | 01:13 PM
acurod's Avatar
Heavy-
I found what you mean. No, it won't reconnect when i press that "headset" button. Call stay on on the phone, but not car.
Rod
Old Oct 8, 2014 | 01:59 PM
HEAVY_RL's Avatar
One more thing... Go to Bluetooth in settings and make sure the car is paired, then click the gear beside the car in the list and make sure "call audio is checked.
If all is correct, try dialing from the phone and connecting (with out using the steering wheel) and see if it drops.
Old Oct 8, 2014 | 06:12 PM
acurod's Avatar
while not in the car I am trying to check the call audio box, and it won't allow it to be checked. Is this a problem? Should I be doing this while in the car?
Thanks for all your help Heavy!
Old Oct 9, 2014 | 07:22 AM
HEAVY_RL's Avatar
Sitting in the car... as you normally would... connect to the cars blue tooth... check the box... and make a call via the phone.
Old Oct 9, 2014 | 09:49 AM
acurod's Avatar
tried to check the box and it wouldn't allow it to be checked. could not connect with car's bluetooth.
Old Oct 9, 2014 | 11:24 AM
HEAVY_RL's Avatar
thats your issue... start with a re-sync on the phone (delete/add), if that doesnt work its your hardware in the car.
Old Oct 9, 2014 | 01:24 PM
acurod's Avatar
Thanks Heavy-
I suspect it is the software update, since after the update the phone is not working in either of my acuras. Before the update phone worked fine in both cars. And my wife's iphone works fine in the MDX.
I just have to hope that Samsung/Google can correct this in a patch or next edition of Android OS.
Rod
Old Oct 9, 2014 | 04:26 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
Next time I can't login to my email account I'm calling you Heavy... Apparently you moonlight as tech support.
MetalGearTypeS
Aug 29, 2016 08:28 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
thegipper
Sep 28, 2015 01:01 PM
navtool.com
Sep 25, 2015 05:15 PM
