Front door speaker removal
Hello people, does anyone know how to change the front door speakers. I have one that is buzzing, and sounds awful. I found a pair of infinity speakers on line to replace the stock ones. They are 6-1/2" 2-Way Reference Series Shallow-Mount Car Speakers
Power Handling:
Peak: 300 watts per pair / 150 watts each
RMS: 100 watts per pair / 50 watts each
Plus One+ Injection-molded, polypropylene cone woofer
Hi-roll rubber surround
1" Edge-driven, textile dome tweeter
Intermount III Mounting system for 6-3/4" openings
True Four Ohm Technology - speaker's 2 ohm impedance combines with OEM speaker wire impedance for a 4 ohm load
2 ohms impedance
Top-mount depth: 1-15/16"
Authorized Internet Dealer
1-year Manufacturer's warranty
Power Handling:
2 ohms impedance
because the oem speaker is built into the plastic housing that comes off in one piece. and those adapters do not work either. you need to make a MDF adapter to work properly since the oem opening in the door is not a perfect circle
https://acurazine.com/forums/2g-rl-2005-2012-76/picked-up-new-dd-894665/
Post 33.
If this isn't something you're used to doing you may want to have a professional do it to avoid damaging the door panel.
Post 33.
handsom-hustla
Nov 13, 2015 05:04 PM
