FM Radio Question
Old Feb 4, 2012 | 11:53 PM
elemgee's Avatar
FM Radio Question
I have an 05 RL and have noticed several times in the past couple of weeks that when I press the AM/FM radio button, the AM stations will appear. As you know, when you press that button, the FM pre-select stations (either FM1 or FM2) are to appear. I then pressed the button again to get the FM stations, and when i pressed button 1 for the 1st pre-selected station, all I got was static. Same for the other stations as well. It's like the antenna is disconnected.
A couple of hours later when i got back in the car, everything was fine.
Anyone else have this problem, and know how to fix it?
Larry
Old Feb 5, 2012 | 09:59 AM
HEAVY_RL's Avatar
Are you using two different remotes that have different presets?
Old Feb 9, 2012 | 08:11 PM
elemgee's Avatar
Sorry, but I dont follow the question. I dont use any remote for the stock radio.
Old Feb 9, 2012 | 10:31 PM
oo7spy's Avatar
Remote = fob. The car will save presets for each fob.
(Fob = key-less remote )
When you say all you get is static, are you sure it was on a good station. Also, did you happen to be under any sort of concrete or metal structure? When was the last time you replaced the battery?
Old Feb 10, 2012 | 07:27 AM
HEAVY_RL's Avatar
^^this... is could be the tints
Puma Jim
20
Oct 20, 2016 11:59 AM
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
tmux
Sep 21, 2015 05:11 PM
datadr
Sep 12, 2015 09:12 PM
