FM Radio Question
FM Radio Question
I have an 05 RL and have noticed several times in the past couple of weeks that when I press the AM/FM radio button, the AM stations will appear. As you know, when you press that button, the FM pre-select stations (either FM1 or FM2) are to appear. I then pressed the button again to get the FM stations, and when i pressed button 1 for the 1st pre-selected station, all I got was static. Same for the other stations as well. It's like the antenna is disconnected.
A couple of hours later when i got back in the car, everything was fine.
Anyone else have this problem, and know how to fix it?
Larry
Larry
Remote = fob. The car will save presets for each fob.
(Fob = key-less remote )
When you say all you get is static, are you sure it was on a good station. Also, did you happen to be under any sort of concrete or metal structure? When was the last time you replaced the battery?
Puma Jim
20
10-20-2016 11:59 AM
BoricuaTL
04-08-2016 01:08 PM
