Factory Cd Player Help
Old Sep 30, 2009 | 09:08 PM
sigmawill's Avatar
4th Gear
I have a 06 RL and my factory 6 disc Cd changer in dash is no longer reading CD's. I have bought a lens cleaner and that did not work either. I am lost. It just acts as if its trying to read the CD then it spits it back out. Any help would be useful. Maybe a quick fix? Are some where I can take it that it want be so expensive. In Austin Tx. area.
Old Oct 7, 2009 | 02:28 PM
jtevis's Avatar
I ended up buying a salvage unit for 300 that solved my problem....
Old Oct 8, 2009 | 06:59 PM
sigmawill's Avatar
4th Gear
Man hope there is a easier fix than that
Old Oct 8, 2009 | 09:50 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Are you out of OEM warranty on an 06 RL?
I would have an Acura tech diagnose. If the unit failed, you may get a replacement under warranty.
Old Oct 10, 2009 | 11:49 PM
sigmawill's Avatar
4th Gear
I don't think so what is the mileage for warranty on the 2006 acura's?
Old Oct 11, 2009 | 09:04 AM
Chas2's Avatar
50000/4 years; 6 years/70000 on powertrain
http://www.hondanews.com/categories/...5?archive=2006
There is a +5% on the mileage because of a glitch in the digital odometer
Old Oct 20, 2009 | 12:10 AM
manderson's Avatar
Did you find a solution?
I have the same problem.
Any Help will be apretiated.
Old Oct 21, 2009 | 03:21 PM
manderson's Avatar
I found out that the Radio/CD changer and the Navi is manufactured by Alpine.
You can send them your unit and they will fix it for $148 to $208 US Dolars
The address is:
Alpine Electronics
2012 Avaloni Avenue
Unit D
Torrance, CA 90501
Hope this helps
Old Oct 25, 2009 | 05:45 PM
Real Legend's Avatar
My disc wouldnt eject, anyone knows a quick fix?
Old Nov 1, 2009 | 04:37 PM
sigmawill's Avatar
4th Gear
The address is:
Alpine Electronics
2012 Avaloni Avenue
Unit D
Torrance, CA 90501
Hope this helps
Just trying to see if you sent your unit in and what luck did you have. Turn around time etc.
Old Nov 22, 2009 | 04:56 PM
Blazing GT's Avatar
this car when it comes to electrical things is a PITA..
My CD player just stopped working today...it sits there...and reads...and reads....and reads....does not even play....for all the 6 discs
Old Dec 18, 2010 | 03:16 PM
disciplejoe21's Avatar
8th Gear
the same thing just happened to my 06... any solutions found???
Usmcgrunt47
Oct 13, 2023 09:35 PM
rcs86
Aug 2, 2016 06:52 PM
Fool
Mar 10, 2016 08:42 PM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
