Delete Entire Phonebook
Perhaps this is an RTFM question, nonetheless, how does one go about deleting HFL phonebook. I have entries from a previous owner which i would like to erase and get a fresh start of
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
unplug the battery
or you could tell the dealer that it does not want to stay connected and are using a 100% compatible phone, it gives static and does not understand you, saying 888 instead of the numbers given. This way you get a new clean unit.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by calvin_hobbes
any leads on the above question?
ANYONE.... ANYONE (hint: ferris bueller)![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
You can also delete HFL entries one at a time. Press the button, say "Phonebook", then press and say "delete" then say the name that you want to to delete. "List" will return the list of names if you don't know them all.
This is all listed clearly in the manual in the HFL section.
Press the HFL button, and say "System". The HFL should respond with "System options are Setup and Clear". If you press the HFL button again and say "Clear" it will clear all phonebook entries, paired phones, and the passcode if set. You will obviously need to re-pair your phone after this.
Originally Posted by csmeance
unplug the battery
thanks dwboston. This is what i was looking for :-) this is not listed in the '05 RL manual which i have.
I'm pretty sure it's in the hard-copy manual as well.
Originally Posted by dwboston
It's listed in HFL section in the 2005 RL manual that's online here: https://techinfo.honda.com/rjanisis/...505MAINIXA.pdf
i triple checked my hardbound manual which came with RL, and this information seems to be non-existent. I guess there has been a revision of the hard-copy manual?
DerrickW
11-15-2015 05:52 PM
johnpancakes014
09-27-2015 12:58 PM
