Chinese interface
Old Dec 16, 2013 | 01:52 PM
Türk's Avatar
Unhappy Chinese interface
Hello everyone.
I hope you are all keeping well.
I need an asistance. But firstly, please accept my apologies for my bad English
I bought a VIDEO INTERFACE from China. I tried to install but result; NOTHING
I could reach the socket of display by removing the center speaker.
Then, I've tried to find the problem and figured out something.
As seen on the following photo, there are some cables which goes to display directly.
I found that these cables are related to RED, GREEN and BLUE video signals :S
8-Red color signal
9-Green color signal
10- Ground for display unit
18- Blue color signal
19- Composite video
20- Shield for No. 8, 9, 17, 18, 19 terminals
The color codes also fits to my display cable codes.
The cables which goes to INTERFACE BOX are Ground, ACC+, ILLUMINATION etc.
How will the box switch diplay via these pins?
So...
Am I connecting to device a wrong place or has the stupid Chinese guy connected cables to wrong terminals?
Regards,
Türk
Old Dec 16, 2013 | 04:06 PM
BDoggPrelude's Avatar
Oh my lord. What on earth are you trying to do there?
www.navtool.com
Old Dec 16, 2013 | 04:51 PM
HEAVY_RL's Avatar
ok, so most of the interfaces for Nav/Video interrupt the signal at the DVD player in the trunk.
Can you post a link to the site where you bought this version?
Have you heard of this unit? http://www.navtool.com/?gclid=CNH--p...FclQOgodHX0AAg
Lastly what is your end result? a back up camera?
Old Dec 16, 2013 | 04:55 PM
Türk's Avatar
www.navtool.com
To buy new one is easy way.
Any technical support?
Old Dec 16, 2013 | 05:03 PM
HEAVY_RL's Avatar
yes the easy way, but what you have now seems to have a RGB input and most devices only output in yellow video cable.
So you will need a conversion box or to use port 19 and wire it to a female video cable.
Old Dec 16, 2013 | 05:07 PM
Türk's Avatar
I bought that when I was in Shenzen.
The link is below:
http://www.eglober.com/
I know Navtool buy it was more than 500 USD including shipping. :S
It was 200 USD morning time (when I asked you on other topic) now 340 USD.
They are crazy I think.
So, you tell me to try disc drive in trunk?
Old Dec 16, 2013 | 05:09 PM
HEAVY_RL's Avatar
see my reply above...
If I am reading the link correctly, you need to wire this plug into the factory RGB harness.
and this looks like the switch to interrupt the signal.
the downside is I do not see acura listed nor do I see the Legend in the honda list... so I cant be certain that is going to work.
Old Dec 16, 2013 | 05:12 PM
Türk's Avatar
No. That device supports RGB in also.
I also bought a small RGBS out GPS BOX to connect to interface.
http://www.eglober.com/ProductShow.asp?ID=1942
http://www.eglober.com/ProductShow.asp?ID=2030
Old Dec 16, 2013 | 05:13 PM
Türk's Avatar
I'm writing from mobile and I'm not far enough.
It's 1:15 am here
Old Dec 16, 2013 | 05:14 PM
HEAVY_RL's Avatar
oh ok... our posts are out of order, let me know when you catch up.
Old Dec 16, 2013 | 08:40 PM
oo7spy's Avatar
Try the trunk.
Old Dec 17, 2013 | 05:43 AM
Türk's Avatar
Originally Posted by oo7spy
Try the trunk.
Thanks.
Do you have the cable scheme of the trunk DVD Rom?
I need to understand the system
Regards
Old Dec 17, 2013 | 07:27 AM
db22's Avatar
Maybe you got the unit for the Benly or the Lang Rover!
Old Dec 17, 2013 | 08:52 AM
HEAVY_RL's Avatar
So I believe the harness is the same in the trunck as it is in the dash so that is a moot point.
But I agree with DB2, we have no way to prove you have the right product for this car.
I will caution you that since you are behind the dash, accidentally feeding 12v to the wrong wire could cause damage to other components.
Old Dec 17, 2013 | 09:17 AM
Türk's Avatar
Hey there.
I was writing via mobile, sorry my typing errors
@HEAVY_RL
Acura and Honda use the same technology. RL or Legend are not known in China much.
As you can see, this box is HONDA ODYSSEY, HONDA PILOT, HONDA RIDGELINE compatible like NavTool HA20PIN.
http://www.navtool.com/acuraRL_05-08.aspx
I have the cables for RGB-Video in and selector switch, they are ok.
On the other hand, I've found the cable scheme.
01-02-03-04-05-xx-xx-08-09-10
11-12-13-14-15-xx-17-18-19-20
01- RED
02- GREEN
03- SHIELD
11- BLUE
12- CSIG
13- GROUND
So, I think my previous installation is incorrect.
I afraid this device has blown. Because I've sent +12 Volt to RED color signal pin with my previous installation
I want to kiss that China guy's wife and daughter at the same time
Old Dec 17, 2013 | 09:25 AM
HEAVY_RL's Avatar
hahahahahah!!
Yes I think you fried something.
On a similar note, you and I know they are the same BUT this China site may not have listed it for a specific reason.
Old Dec 17, 2013 | 09:30 AM
Türk's Avatar
I think the device is correct but my connection was not.
I wonder something.
What happens if I connect RGB signals from Navi to a RGB monitor as below?
Old Dec 17, 2013 | 09:34 AM
Türk's Avatar
hahahahahah!!
Thanks for advice but there is no reason to not work, as my device did not work.
I'm looking for a guy who wants to buy and send me a Navtool as a Christmast gift, even I'm a Muslim
Old Dec 17, 2013 | 10:15 AM
oo7spy's Avatar
The display and DVD are the same except some wires do not connect directly.
Old Dec 17, 2013 | 11:18 AM
Türk's Avatar
Yes. But pin connections are different.
I've found and shared above.
Old Dec 17, 2013 | 01:05 PM
oo7spy's Avatar
Just realized how useless my diagram is without any pin descriptions.
Old Dec 17, 2013 | 03:01 PM
Türk's Avatar
It's ok
What about connecting the interface cable to main unit directly under dash?
I have a touch screen controlled GPS box and its cable is very short.
The cable which comes from trunk should be connected to main unit.
BTW, still looking for a Christmast Gift buyer
Old Dec 17, 2013 | 03:49 PM
oo7spy's Avatar
I don't know what you are asking. The harness from the DVD player to the screen are directly connected.
Old Dec 17, 2013 | 04:05 PM
Türk's Avatar
From trunk to display?
Directly?
R u sure ?
Old Dec 18, 2013 | 08:00 AM
db22's Avatar
Heavy, my spelling was not a typo, I got it from their web site.
Old Dec 18, 2013 | 08:39 AM
Türk's Avatar
Yeah, I know.
Even their Chinese is worse than my English
God bless me
I'll try that trunk job this weekend.
On the other hand, what about connecting RGB to Navtool?
Possible?
Regards
Old Dec 18, 2013 | 09:20 AM
HEAVY_RL's Avatar
Oh man...
Old Dec 18, 2013 | 09:23 AM
HEAVY_RL's Avatar
God bless me
I thought you were Muslim!
Possible?
Nav tool is plug and play in line with the DVD player. You wont need to splice that RGB imput.
Once installed it interrupts the signal with a yellow video input cable.
Old Dec 18, 2013 | 10:00 AM
Türk's Avatar
Thanks for reply.
I'm Muslim but believe in the same God.
God, Allah... They are all same for me.
I'm not a religion guy. But I feel and believe Him.
About RGB, I have a RGB out GPS box.
First, I will try to repair my Chinese interface and install.
Price is shaking on Navitool.com again.
Yesterday 200,00 USD, now 340.00
Old Dec 18, 2013 | 02:01 PM
oo7spy's Avatar
Directly?
R u sure ?
Trunk to display directly. I am sure. The picture I posted before is the continuity map between the two harnesses.
From what I remember on the NavTool, there is an older model (red?), and an "updated" model (silver/white?). The new one is asking $340, but the old one is/was much cheaper. Maybe look for that.
Old Dec 18, 2013 | 02:12 PM
Türk's Avatar
Thank you for the message.
How many inputs does display have?
I think only one.
If there is only one input to display, how are the other signals (A/C, radio, trip computer etc) sent?
I'm confused.
Old Dec 18, 2013 | 03:00 PM
oo7spy's Avatar
I think only one.
I'm confused.
Sorry, I was wrong. I assumed the 20 pin Navigation harness was the DVD-ROM harness. Bad assumption. You really need the service manual. I tried to attach the Navigation System PDF. Start on page 16.
File Type: pdf
Old Dec 19, 2013 | 07:38 AM
Türk's Avatar
Thank you.
I also got this manual from an other topic.
Thanks to AcuraZine
Old Jan 16, 2014 | 04:23 PM
MyKL's Avatar
Crazy Russian
Amazon.com: Intelligent Car Video Switcher 3-way Input 1-way Output for the Car Camera: Car Electronics Amazon.com: Intelligent Car Video Switcher 3-way Input 1-way Output for the Car Camera: Car Electronics
Old Jan 16, 2014 | 04:46 PM
MyKL's Avatar
Crazy Russian
Old Jan 19, 2014 | 02:09 AM
Türk's Avatar
Thank you for scheme.
What about removing display?
I got 8" touch panel from China.
I searched service manual but removing display is not clear.
Should I remove wooden trim?
Old Jan 19, 2014 | 10:49 AM
MyKL's Avatar
Crazy Russian
My tech guys used special order(custom) size of the touch panel. The standard size doesn't feet .
As I remember they didnt removed wood trim.
BoricuaTL
Apr 8, 2016 01:08 PM
navtool.com
Nov 16, 2015 08:03 PM
navtool.com
14
Oct 31, 2015 08:16 PM
AZuser
Sep 17, 2015 10:15 AM
jesseray
Sep 14, 2015 05:58 PM
