Change the OK/startup screen on a 2006 RL
I cannot belive that there has not been some discussions around how to change the default screen on an [B]2006 RL[/B] to something other than the words that now apear... Maybe it is not possible but I thought I saw, at a dealer the other day an Acrua that had the startup screen with a picture of a family on it...
I am sorry if this has been discussed before I could a thread so if someone could kindly point me in the right direction it would be much appreciated!!
THanks
Gary
THanks
Gary
THanks
Gary
THanks
Gary
with the RL, the only thing that you can change is that startup screen which has the acura logo on it to something else, the auto-ok button only works for the 3.xx disks, the 4.xx disks which the RL and all 2007+ acuras use do not support it.
Somebody makes an "Ok" enter module, but I forgot who it was. I've got the link bookmarked on my PC at home if anyone needs it. I'll probably get one for my car. Its not a huge deal to press ok but still it shouldn't have to be done every single time I start the car.
here's a link to a company that makes an "ok" module for the NAV. http://www.kptechnologies.com/
I would be interested to know how the physical connections are made in the RL. Inserted in between plugs in the wiring harness (that would be ideal but I sort of doubt it), cutting and splicing wires (well - maybe - I do know how to solder and use proper crimp connectors plus have the necessary tools - sort of what I do for a living AND a hobby) or use the wire tap thingies that tap into the wire by slicing through the insulation and likely breaking one or two strands of the wire at the same time (no f...in' way!!!)?
