CDs won't load
Old Jul 15, 2012 | 01:53 PM
Ragus's Avatar
CDs won't load
I have a 2006 RL and when I try to put a CD in nothing happens.
The first time I tried, the LED CD light flashed red, after that, nada.
I tried holding the LOAD button and nothing happens. Pressing DISC, EJECT, etc does nothing either.
Anyone else seen this issue before?
Old Jul 16, 2012 | 10:17 AM
oo7spy's Avatar
Sounds like you were on the right track, no pun intended. Next time try the owner's manual.
Originally Posted by Your handy-dandy manual, pg 225
To load a single disc:
1) Press and release the LOAD button on the changer unit. You will see ‘‘BUSY’’ on the upper display, and the disc load indicator turns red and starts blinking.
2)Insert a disc into the disc slot when the disc load indicator turns green, and ‘‘LOAD’’ appears on the upper display at the same time. Insert the disc only about halfway; the drive will pull it in the rest of the way. You will see the disc number blinking on the upper display, and the disc load indicator turns red again and blinks as the disc is loaded.
Do not try to insert a disc until ‘‘LOAD’’ appears. You could damage the audio unit.
3)You will see ‘‘DISC READ’’ on the upper display, then the system begins to play the disc.
Old Jul 17, 2012 | 04:19 PM
IanVS's Avatar
Perhaps the green light isn't working. Like spy said, check the upper display to see if it's ready.
knight rider
Mar 4, 2016 08:59 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
joflewbyu2
Oct 8, 2015 11:16 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
