Add a fuse issue
Add a fuse issue
I am trying to hardwire my V1 radar detector into my 2006 RL. As several posts suggested, I got a mini add a fuse (specifically a Buss Fuses HHH accessory mini add a line) and crimped the wire to the V1 direct wire assembly. I attached the ground from the direct wire assembly with a screw and nut to the metal frame that holds the diagnostic plug. I removed the 7.5amp radio fuse and plugged the add a fuse in with the original fuse at the bottom and a 2 amp fuse for the top. I plugged the add a fuse in....no power to the radio (as it should be) but, the radar dectector had power (to be clear, this is with the ignition completely off). I flipped the add a fuse to see if that would make a difference and it still gave ignition off power to the V1. I tried the TPMS fuse too and get the same result (thinking the TPMS fuse had to be a switched one too).
I am stumped
! I would greatly appreciate any suggestion or even an explanation on how this is possible!!!
I am stumped
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
You chose a fuse that is always hot. The manual has a fuse map that will tell you which are which.
What fuse # did you use?
Here is one...can't find the other I saw from a google search.
https://acurazine.com/forums/showthr...hardwire+radar
Someone else used the ACC fuse, so I guess I will try that next...
Use the ACC fuse.
mugen_kid
11-13-2015 10:38 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
drewdeezy03
09-03-2015 08:04 PM
