Your Opinion, Please!
Old Sep 9, 2013 | 10:14 AM
thephantom's Avatar
Some of you may recall that I've had an annoying vibration/car shake starting at around 70MPH and gets worse as the speed increases. I've done the following and it's only made a minor difference:
1. Replaced front and side motor mounts
2. New Bridgestone Turanza Serenity Plus tires
3. New brakes (although not OEM)
4. Four wheel alignment
5. Balanced the wheels twice in one week
Any idea what I should look for next? I am at my wits end with this issue and my extended warranty ends in January, so I'd like to get this issue resolved before finding out it's going to cost me an arm and a leg.
Thanks for you input!!
Old Sep 9, 2013 | 10:29 AM
JnC's Avatar
JnC
Former Sponsor
Who is doing your wheel balancing?
Check to see if they are doing high speed wheel balancing. Most shops use low speed wheel balancing technique/machines and thats one of the reason why at high speed you feel the vibration. I had this happen to my old 2G RL till someone suggested getting high speed balancing done, which solved the issue.
Also, get your suspension bushings such as control arms, tie rods etc checked for cracks etc.
BTW is your car for sale as I see an ad on local CL with your avatar picture in it.
Old Sep 9, 2013 | 10:42 AM
thephantom's Avatar
Dealer and NTB both balanced the wheels within a three-day period. I had the rear sway bushing replaced a few weeks ago by an Acura dealer.
Yes, that's my car. My wife are I are expecting and was/is contemplating on getting a larger vehicle.
Old Sep 9, 2013 | 11:05 AM
JnC's Avatar
JnC
Former Sponsor
Try getting them properly torqued.
Getting them tightened by an impact gun at NTB or dealer doesnt guarantee properly torqued wheels, in fact they get over torqued this way.
I believe proper torque for each lug bolt is 80~85 lbs/ft.
Old Sep 9, 2013 | 11:48 AM
oo7spy's Avatar
Road force balancing? I know there have been other members that have had their tires balanced multiple times and it wasn't until someone did it just right that the vibrations were fixed.
Old Sep 9, 2013 | 04:58 PM
thephantom's Avatar
I have done roadforce in the past and that didn't help.
Old Sep 12, 2013 | 05:00 PM
MrKev's Avatar
During the vibration does your steering wheel shimmy left and right or is the wheel perfectly straight but you feel car vibrating up and down?
Shimmy left and right on steering wheel is wheel balance but if you feel the car shaking up and down like you going over little bumps is either bent rim or axle is bad
Old Oct 7, 2013 | 02:54 PM
thephantom's Avatar
So, almost $1,000 later...
Rear passenger rotor was causing 50% of the vibration since it's warped at the "hat". Replaced both rear rotors, vibration reduced to 50%.
The mechanic removed the propeller shaft and it made a little difference, but not enough for me to look further.
Since I have felt some vibration in the steering wheel, I also had the front rotors and pads replaced, just for good measure.
I just got the car back so have not had a chance to drive it, but I'll check it out on my way home and during my commute tomorrow morning. I doubt the car is going to be smooth, but I sure hope it improves.
Old Oct 7, 2013 | 04:27 PM
oo7spy's Avatar
I was a bit leery at first, but took a chance on a full set of front and rear brakes (cross drilled and slotted rotors with ceramic brake pads) from Brakemotive after seeing some reviews. The price was very good at under $200 for the full set including shipping! In any case, I had them installed on Saturday and they are by far THE BEST set of brakes I have ever purchased!!
Originally Posted by oo7spy
I hope they are everything they are talked up to be, but I am not sold.
"You get what you pay for" & "too good to be true" are common life lessons that come to mind and aren't common because they are usually wrong.
Old Oct 7, 2013 | 04:42 PM
HEAVY_RL's Avatar
uh oh...
Old Oct 7, 2013 | 07:05 PM
thephantom's Avatar
Well, at the time, they were great. I am not sure if the warping was due to manufacturer's defect or something I did, but they did perform well under hard braking or just everyday braking. The new brakes are blank rotors and they feel a bit mushy compared to the cross drilled and slotted ones, but they'll do.
Old Oct 7, 2013 | 07:44 PM
Sniffles's Avatar
go claim warranty before your year is up...they'll send you another set for free....use it for another 6 months lol
Old Oct 8, 2013 | 07:55 AM
oo7spy's Avatar
If you only replaced the rears, this doesn't make much sense. The vast majority of braking power comes from the front.
I honestly mean this as sincerely as possible, but have you tried just enjoying your car? Cars make noise, and spinning parts vibrate. There is always something that "could" be wrong, and if you are actively scrutinizing everything about the car, you are going to find something. Put some subs in the trunk, turn up the volume and enjoy driving a machine for what it is. Your car will never be a cloud unless you buy a Model S.
HOWELLiNC
Wash & Wax
35
Jul 16, 2017 04:13 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
eastcoastguy
Sep 23, 2015 06:29 AM
dlknight
Sep 3, 2015 07:54 PM
