windshield sprayer nozzle
Old Jun 20, 2010 | 10:35 PM
pearlrl's Avatar
one of my windshield sprayers is not working any suggestions on how to fix this without going to the stealership ?
Old Jun 21, 2010 | 05:59 AM
christopher1's Avatar
lift the hood
look for the hose that runs to that sprayer. this is very easy, if your one side works then its all about connection. or take a safety pin push in the sprayer, that does not work see if clogged. if those simple things do not work,go to the dealer.
Old Jun 21, 2010 | 09:43 AM
Chas2's Avatar
If you happen to have a hypodermic needle, my dealer uses one of those to force air through the clog, or at least he did some years ago on my Legend. Have not had any issues with this car.
Old Jun 21, 2010 | 06:29 PM
tvande's Avatar
06 RL - 04 TL
Haven't tried it on my RL, but on other cars, I've been able to clear built up wax residue etc by using a straightened out (small - not one of the bigger ones) paper clip.
If it's just one side not working, then usually a clog of some sort. If none of the washers are working, then look at the hoses coming from the washer bottle/pump. Might even have a helped actuate the pump while you hold the disconnected line to make sure the washer pump is working.
Tom
Old Jun 21, 2010 | 09:29 PM
pearlrl's Avatar
thanks i stuck a needle in it and it works !
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
