windshield sprayer nozzle
lift the hood
look for the hose that runs to that sprayer. this is very easy, if your one side works then its all about connection. or take a safety pin push in the sprayer, that does not work see if clogged. if those simple things do not work,go to the dealer.
Haven't tried it on my RL, but on other cars, I've been able to clear built up wax residue etc by using a straightened out (small - not one of the bigger ones) paper clip.
If it's just one side not working, then usually a clog of some sort. If none of the washers are working, then look at the hoses coming from the washer bottle/pump. Might even have a helped actuate the pump while you hold the disconnected line to make sure the washer pump is working.
Tom
Tom
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
