window electrical problem
Old Aug 14, 2012 | 10:17 AM
antle1101's Avatar
Wink window electrical problem
I have a 06 rl. Just happened. I cannot roll down both rear windows from using the driver's master switch. But it will roll down only if i use the window switches fom the rear. Anyone ever had this issue? I want to try and figure it out first before bringing it to the dealer or mechanic.
Old Aug 14, 2012 | 10:51 AM
HEAVY_RL's Avatar
search is your friend
Old Aug 14, 2012 | 11:46 AM
db22's Avatar
Search is no way your friend, at least not the search on this forum.
Old Aug 14, 2012 | 11:52 AM
getakey's Avatar
Here
https://acurazine.com/forums/showthread.php?t=865126
Old Aug 14, 2012 | 01:36 PM
antle1101's Avatar
I did the 5 second roll up and down. Still not functioning. Also checked child safety locks. Any other suggestions?
Old Aug 14, 2012 | 01:52 PM
getakey's Avatar
I would do the procedure again exactly as noted in the other thread
Old Aug 14, 2012 | 01:57 PM
HEAVY_RL's Avatar
as with life some get along better than others...
google has spoiled us
Old Aug 14, 2012 | 02:32 PM
getakey's Avatar
You can used advanced search in google to specify the site that you want to search.
Just enter rl.acurazine.com and you have google search for this forum
works well
Old Aug 14, 2012 | 03:03 PM
antle1101's Avatar
To reset do i push down only on the main switch or the switch that is not working?
Old Aug 14, 2012 | 03:08 PM
getakey's Avatar
The rear switch, NOT the master on the driver door
Old Aug 14, 2012 | 05:37 PM
antle1101's Avatar
Got it to work. Had to do it on the rear windows, i was doing it on the master switch this whole time....Thx everyone for ur help. I guess when i chgd battery i had to reset the windows?
Old Aug 14, 2012 | 05:40 PM
getakey's Avatar
Glad you got it to work.
I've changed my battery 3 times and it did not cause this.
I don't know that anyone has a full repro of how it happens
Old Aug 14, 2012 | 06:27 PM
HEAVY_RL's Avatar
nice work Getakey
Old Aug 14, 2012 | 06:47 PM
getakey's Avatar
Just trying to stay 3 levels ahead of you Heavy
Although you should get extra points for Avatar management
Old Aug 14, 2012 | 08:32 PM
projektvertx's Avatar
Agreed.
uzzmaan
Jun 17, 2026 08:56 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
