Why does my radio turn to static when I turn on my HID fogs?
can someone tell me why my radio or Fm transmitter decides to go ape shit whenever I turn on my HID fogs?
music gets so static its not terrible but its enough that your like OMG im gonna punch the radio lol
Is it the radio or your FM transmitter?
The ultimate answer is power supply noise most likely in your grounds.
both it goes away as your driving but holy shit is it annoying while u wait for it to go away
FM transmitter sits inside the arm rest the moment u switch to turn on your fogs its static
How do you know it's both? Does the same static occur when the radio is on an FM channel with good reception?
Knowing that will tell you which ground to try and correct. It could be the ground at your radio, it could be the ground at your transmitter. You could potentially improve the issue by grounding your HID ballasts closer to the lights with a solid connection.
dirleton
08-06-2024 08:19 PM
seoulTL
10-11-2015 09:52 PM
MetalGearTypeS
09-30-2015 07:54 AM
