where can i get a...
Old Aug 18, 2012 | 06:40 PM
christopher1's Avatar
Hfl module for 2005 rl. Not from the dealer it is 800.00 plus!!! My eBay search comes up empty . My hfl started acting up will not allow ( name of phone) to be completed without cutting off. Worked for 5 yrs no problems now will not complete pairing process....???? Tried everything...
Old Aug 18, 2012 | 06:59 PM
Carbon Legend's Avatar
i had a issue with my Samsung Galaxy Nexus (verizon) connecting to the car and after doing some research other people had same problem with phone. Got a new phone problem was solved.
try another phone to pair with the car.
Old Aug 18, 2012 | 07:22 PM
vletnguyen's Avatar
i've been searching for that as well. mine died a few months ago.
lucky for me i'm not forced to drive handsfree. (rarely talk and drive anyway, unless on long trips)
someone here said they found it for 150 on ebay i think.
i thought about calling the junk yards with our car (ebay listings) and ask but havent had the need.
Old Aug 18, 2012 | 07:34 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
acuraoemparts.com wants $641.75
http://www.acuraoemparts.com/delray/...t&ListAll=Part
You might try salvage yards. The HFL module is the same for 2005-2008. It is different in the 2009+ RLs and I do not know if it is backward compatible.
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/bluetooth-broken-752656/
Old Aug 18, 2012 | 07:55 PM
used on ebay P/N 39770:
http://www.ebay.com/itm/2006-ACURA-T...1ae17f&vxp=mtr
http://www.ebay.com/itm/Acura-Honda-...003999&vxp=mtr
http://www.ebay.com/itm/06-07-08-ACU...6f1c29&vxp=mtr (Verify P/N!)
http://www.ebay.com/itm/2010-Acura-T...590bef&vxp=mtr
http://www.ebay.com/itm/09-12-ACURA-...dc5821&vxp=mtr
http://www.ebay.com/itm/2010-Acura-T...8253db&vxp=mtr
http://www.ebay.com/itm/07-11-Acura-...c6a0d4&vxp=mtr
Old Aug 18, 2012 | 09:02 PM
HEAVY_RL's Avatar
boom...
Old Aug 18, 2012 | 09:43 PM
vletnguyen's Avatar
tampa.. you are the man.
i have been searching for part number 39770-SJA-A01
noticed the the three letter prefix (SJA) are a tad different through various links provided.
didnt know they where compatible with other models..
for $150 i'll probably order it sometime this week.
thanks again tampa.. maybe we can meet up for coffee or something next time i'm in town.
Old Aug 18, 2012 | 09:54 PM
You will find many Acura parts are the same as the Honda counterpart. It appears they RL / LEGEND uses the same component as the TSX / EUROACCORD. Both being Japan builds, it further makes sense they share the same component. The TL however, does not use the same BT Module.
The RL & TSX module is made by Johnson Controls.
The TL module is made by Bluecon.
But the P/N for the TSX module is the same as the RL. The A01 is simply the Acura version of the P/N.....and typically more $$$ than the corresponding Honda P/N.
Deal on the coffee.
Old Aug 20, 2012 | 01:04 PM
BluNosr2's Avatar
What's involved with installing a replacement HFL module? My friend also has an 05 RL with the same issue.
Old Aug 20, 2012 | 01:22 PM
Originally Posted by HEAVY_RL
boom...
Goes the dynamite
Old Aug 20, 2012 | 01:47 PM
I posted this think above where LL describes the replacement process.
https://acurazine.com/forums/showthread.php?t=752656
The links to the used BT modules above are mostly for TSX. Althought the primary part #s are the same, the casing of the modules are slightly different. They may not mount exactly the same, and you may need to modify the mounting with tie straps or velcro. Its behind the glovebox, so it has no cosmetic impact.
chayos00
Mar 29, 2021 09:14 PM
AcucaDude
Nov 10, 2014 02:23 PM
tblood
Dec 12, 2012 03:22 PM
knight rider
Nov 1, 2012 09:52 AM
