What are some things that could cause this?
Old Mar 6, 2020 | 07:50 PM
Jut's Avatar
Jut
I'm in the process of changing my valve cover gaskets and seals on my 05 RL and noticed that bank 2 is dirty as hell and bank 1 is perfect looking. The car drives great and I've changed every fluid there is to change. It has new plugs and I don't use cheap fluids or parts. The only issue I have is my millage hasn't gone above 11.8 mpg and I do have a P0430 code. The driving is probably 99% around town.
Old Mar 7, 2020 | 12:41 PM
Blues Legend's Avatar
I'd say check the breather pipes are clear, etc as a first step.
I note the EGR valve is on that bank, but I'm struggling to see how it would cause that. It could explain the P0430 code though.
If the rear spark plugs are loose, perhaps the rear bank is running cold and inefficiently?
Just guessing, really.
Old Mar 7, 2020 | 05:42 PM
Jut's Avatar
Jut
Thanks for your thoughts, I'll check everything. What do you think about my milage? Is it typical for an older RL? I don't drive like a madman or anything. I was thinking about changing the o2 sensors, any thoughts on that?
I do plan on doing the cat but that's one area that I'm really leaning towards aftermarket. Any suggestions on a good one for my car would be a great help.
Old Mar 8, 2020 | 09:30 AM
I get around 16 (Imperial) MPG driving around town (bit of a leadfoot) so I'd say yours is definitely running rich.
O2 sensors are probably another 'easy' check - if you can unscrew them.
That sort of gunking seems to be a common problem with VCM-equipped J35s - I found this thread which might help:
Here
Old Apr 1, 2020 | 11:08 AM
TonyCD's Avatar
That's bad MPG even for the rather thirsty RL. Even in town, you shouldn't go below about 14 unless you're an absolute leadfoot.
Old Apr 3, 2020 | 07:55 AM
Jut's Avatar
Jut
I actually drive more like an old lady. Once in a while I step on it to see what it can do but I'm mostly real easy with it. I just put a new bank 2 sensor 2 in and my milage actually went down by almost a half mile. I'm probably just gonna have to bite the bullet and change my front cat. Any suggestions on good aftermarket? I did check the temp coming in and going out and it was almost equal, just a 20-30° difference
Old Apr 3, 2020 | 09:49 AM
i believe the discoloration is from heat..
kaza
Dec 24, 2015 10:27 AM
Vlad_Type_S
Jan 23, 2013 06:05 PM
914k24CL9
1G TSX Photograph Gallery
Jul 30, 2009 09:44 PM
CL9K24NJ
Mar 30, 2009 01:36 PM
l7h8626
25
Apr 7, 2006 12:28 PM
