Transmission question re: 05-08 vs 09+
I know the 09+ has a different gate/shifter vs the 05-08...
I also already know the 09+ lets you change gears via the paddle shifters even when not in "sport mode"... and you can't use the stick/shifter to select gears on teh 09 like you canon the 05-08.....
here is what I DON'T know... is the 09-10 transmission otherwise the SAME as an 05-08? boht are 5AT transmissions... but are the gears the same? is the transmission programming teh same?
how about shifts - are they the same or can the new transmission change gears more quickly?
just wondering, if aside from the shifter and ability to select gears while in drive mode - is the actual transmisssion on the 09-10 any better than an 05-08 or is it really just the same system?
i know the 2011 has a 6AT... not asking about that. focusing on whethe the 5AT in the newer 2G is really any better.. like quicker shifts? less hesitation? or is it the same...
thanks.
thanks.
BoricuaTL
04-08-2016 01:08 PM
