Transmission faults codes and drivability issue
Old 04-27-2009, 08:01 AM
tnormanchevy's Avatar
Yesterday my 05 RL with 47k started hitting through the gears really hard and would flare up on an upshift and act like it does know what gear to put it in. It also locked me out of manual mode and 5th gear. I pulled the fault codes and there was a "P0797 Pressure Control Solenoid "C" Stuck on" code. Two questions....Has anybody ran into this problem? How is Acura on their good will assistance as I'm three weeks out of factory warranty by time? Thanks.
Old 04-28-2009, 05:42 PM
gbriank's Avatar
When did you purchase your RL? I'm sure that Acura may bend on this one (since you've not hit 52,500 miles). Maybe ask for some "goodwill"...
Old 04-28-2009, 08:54 PM
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
I did a search of the site and didn't find a similar code noted. Some dealers will offer goodwill for this situation.
Old 04-29-2009, 10:42 AM
Randy is the Future
nore03's Avatar
Why wouldn't this be covered under the powertrain warranty..... I don't know much about that warranty but isn't that type of stuff covered? If not, what is covered?
Old 04-29-2009, 11:07 AM
Chas2's Avatar
Go to your dealer and also note that the speedo in your car is off, that is too say, 5% off in accordance with a class action settlement with Honda, and they ought to take that into consideration.
http://hondaodometerclassaction.com/
Old 05-05-2009, 09:00 PM
Thanks. Just wanted to give an update. Car had gone into limp mode and locked itself out of 5th gear and manual mode. Dealer wasn't able to reproduce problem but it's logged in Acura's service system now. Fluid was dirty and dealer changed and cleared codes. Car working fine now but it's a little troublesome to know it happened and nothings been resolved. Dealer only charged for the tranny service. Does the RL have a longer powertrain warranty than the 5/50k?
Old 05-06-2009, 06:33 AM
Chas2's Avatar
I think the longer warranty started with 06, 6 years/70K miles. Remember there is also the odometer class action where your warranty is extended by 5% by mileage.
mada51589
05-03-2022 08:54 PM
01CLOwner
10-09-2015 01:07 PM
ibGTV
09-28-2015 03:40 AM
carz0159
09-20-2015 06:11 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Transmission faults codes and drivability issue
