Toluene- Octane Booster
Just purchased a 2005 Acura RL.
I am in a unique situation, my family owns a large farm, and we have several tanks of regular unleaded gasoline that we use for farm machinery, trucks, etc. This fuel costs us far less to use compared to buying gas in town.
My question: Can I use Toluene as a octane booster in my Acura RL to raise the octane from 87 to 91 or 93?
There is many threads online concerning using Toluene as a octane booster, and it sounds like it works easily. It would be no problem for me to buy a 55 gallon drum at a chemical store.
I did a search in the RL forum and did not come-up with anything.
Anyone tried this with there RL or other car?
http://sportscarforums.com/f13/tolue...oice-3257.html
http://www.audigeeks.com/forums/index.php?topic=740.0
what we have found on the 3rd Gen TL side, is that our engines ping and knock with 93octane.
some one has used 100octane with 93 to make 96 to stop the knock.
the conversation ended up going to Toluene.
I'm not sure what the general consensus was, but I am down to help you research.
let me finish up some work real quick, and i'll see if i can dig up that thread.
found some info.
You may also want to check out 109 unleaded. It's more expensive but it may be cheaper mixing it at the same octane.
I would go with the race gas over tolulene. I've run a lot of tolulene and xylene and they're fine but with race gas you don't have to worry about running too strong of a mixture.
Tolulene won't make the turbo spool any different.
Race gas is usually formulated to burn a little quicker and optimized for racing. The 109 will supposedly mix better and evaporate quicker for a better cooling effect. There's not a big difference in the two but race gas will probably give a small edge in power.
FWIW, I believe xylene is 116-118 octane and about the same price as tolulene.
If you have a 100 octane station in town, that's the easy winner. It gets old getting out the funnel and mixing tolulene.
I've put about 100,000 miles on leaded gas.
You can't run it with 02s and you can't run it with convertors. Typical heated 02 sensors will last a few tanks of gas with automotive unleaded. Mine lasted about one tank with 100LL aviation fuel.
For pure performance I love leaded race gas. At the time I quite running it, it was quite a bit cheaper for the octane rating than unleaded was. The lead is good for exhaust valves and seats. Lead is a super cheap octane booster.
My car seemed to be less prone to detonation on leaded gas of the same octane.
I highly discourage the use of 100LL av gas in a car or at least in a full mixture. My GN could originally run 16psi boost on 91 and 24psi on av gas. It typically ran about $1 more than 91 so I ran it full time including long trips. As time went on I could run less and less boost without running into detonation. Toward the end (about 1.5 years) I could only run 10psi on av gas and I didn't even bother to find out how low it would be on 91.
I went nuts trying to diagnose it. After I shattered the axle I pulled the heads off (which is how it sits today) and found more lead build up than I thought possible. The pistons have 1/4" caked on as did the heads and you could see where the piston deposits had hit the head deposits. It was probably running 13:1 compression from the original 8.5:1.
100LL has 8 times more lead than automotive race gas. I did not know that at the time and I figured since it has the "low lead" designation it probably had less lead than auto fuels. So I paid the price for being cheap.
This stuff would be a very cheap octane booster in a 50% mixture. It acts as if it has more octane than 100 unleaded. I never verified it but it acts like it has a slower burn rate than pump or race gas. I had to add 4 degrees more timing to make up for the initial power loss.
But back on topic, run the automotive leaded race gas (VP 114 is awesome with it's quick burn rate) if you have no 02 sensors (or a replacement on hand) and no convertors. I've found the Denso sensors to be very tolerant of lead. No one seems to know why but toward the end when I still ran a stockish 02 I only had half a year on the Denso but it never failed.
Sorry, I know this post is all over the place but I'm in a big hurry. I'll clean it up later.
IHC pretty much summed it up as usual
Leaded fuel gives a much higher margin of safety against detonation over unleaded. You can crank up the boost. As a frame of reference, with a good dyno tune I gained over 110whp/110wtq by switching from the 93 octane map to 110 leaded.
Here are the old dyno charts I found in my photobucket:
93 pump gas:
VP 110 Leaded:
93 pump gas:
VP 110 Leaded:
Originally Posted by ihatecars
I agree with your posts.
I did some knock monitoring in the middle of a hot summer and the TL knocks badly in stock form in high temps. I tried different mixtures of 91 and 109 and it took around 96 octane to completely get rid of the knock.
So the answer is to use the highest available octane for the TL. Octane boosters usually have toluene as their octane booster but you can but this stuff at the paint store in a gallon container for about the same price as the 8 ounce container in the autoparts store. The little bottle they sell won't boost it more than a few points at best. 91 to 91.3
octane.
You will see gains of mpg and hp until you get past the point of knock. How much of a gain depends on the severity. You might see a few lbs of torque on the dyno and mpg change would be there.
In a hot summer mine pulls so much smoother and without the initial hesitation from the ECU pulling timing and trying to put it back in constantly. My mpg went way up in city driving but mine was pretty bad without the extra octane.
To the OP, I just wrote nearly this exact thing in another octane thread last night and I have several much more detailed threads on octane out there that you can find with a search.
octane.
your gas light comes on when you have a 3 gallon reserve out of your 17 gallon tank
17-3=14 gallons
30 percent of 14 gallons is 4.2 gallons of toulene
percentages are calculated in this manner
14 (# of total gallons) * (times) .30 (decimal in front of percentage) = 4.2 (the amount of the percentage out of the total)
if you have a smaller percentage, say, 3% you would add a zero after the decimal like this - 14 X .03 = .42 gallons (half a gallon)
17-3=14 gallons
If you want a 3% mix do half a gallon.
You have to count the reserve capacity also.
Just make it easy. Run it down to the light, put 7 gallons fuel then add 3 gallons of toluene. The second time, do 10 gallons of fuel and 3 gallons of toluene.
30% will give approx 96.7 octane.
It's more cost effective to run 100 or 109 unleaded fuel in a mix.
If you are in the US, it's a bit risky to promote that you use 'off-road' / no tax gas or diesel.
Off road diesel is advertised pretty widely here in GA (wink wink) but some folks are caught - it's easy with the red dye tag they use. Huge fines from the IRS.
I am not sure if our gas is given any special tax exceptions as compared to diesel.
Thanks for the info everyone, looks like there is no "NEVER DO THAT, IT RUINED MY RL!!!!" Comments. Now it is time to go buy that 55 gallon drum from the local farm co-op, and learn the correct amount to use.
Will it work? Yes, the only problem is I have heard of some brands "varnishing" components with prolonged use.
The real question is how old is that fuel and how clean is it? Farm trucks are a lot more tolerant that our cars.
The fuel is good. We refill the tanks every month it seems. Each tank has seperate filters to filter the fuel before it goes into tank. I have used the gas forever, and currently use it in my 2007 Tahoe. My big concern was with the 87 vs. the 91 octane, and how I can get it up to 91 octane.
First off, the car will run on 87 octane and there are plenty of people who use 87 (whether they admit it or not)... IMO you could probably get away with boosting every other or even every 3rd tank.
What you will lose is maybe 1-2mpg and some pep as the ecu will keep the motor from detonating.
So I say go for it and track your MPGs... but I would not use the boost in every tank if it were my car.
there are some over the counter octane boosters that work. in the 'old days' i had a turbo chargee / chipped high boost car... it ran best on 93+ octane...and here in CA I could only get 91. my car ran like a BULLET on 100 octane VP unleaded race gas...I found that using the NOS brand of ocane booster that had MMT in it.. I could get my 91 up to about 93..based on seat of pants perforamnce.
another option is to find 100 octane race gas.. buy a bunch of it...and then blend THAT into the lower octane fuel... there are blend charts online that will tell you how much of 91 you have to mix with 100 to get your desired octane rating...
good luck.
good luck.
sockr1
Oct 1, 2015 01:31 AM
