Tire / Slow leaking on CPO CAR?
Hello Guys. I have a slight issue. I bought my CPO RL On the 5th of this month. During which time the TMPS light was on and mentioned to the dealer that the tire was soft " That will be taken care of " Upon taking delivery of the car on the 8th driving home to CT I started to toggle through the TMPS noticed that the same tire was low and left the sales person a message. Not taking it too seriously I had the car in for a door handle replacement at which time I mention to my new servicing dealer that the TMPS was giving mixed reading. " They adjusted the air pressure and said it might be the weather”. To end my curiosity I decided to take it to BJ'S tire repair today as that tire kept showing lower readings they told me that the tire has a small hole close to the side wall and cannot be repaired. What can I do what should I do? The tire does not go flat and if I fill it up every 4 days with just a little air it’s fine. The car has 39,000 miles now also there was not sign of anything in the tire like a nail etc. Is this somethoing i should report to the dealer? or am i alone on this. It's hard to have to buy 4 tires now on a CPO car which should have been checked. Any thoughts
CPO means that the car should be certified to go out the door. An unrepairable tire certainly does not meet that. Did anybody document it? Otherwise start with your sales or service guy, and keep stressing that 1-car was delivered like that, 2-car is unsafe to drive. Go up management ladder accordingly. If they want to change one tire, you might want to do some reading up regarding the all wheel drive system. I think even Acura recommends the tires get changed at the same time, or the new one gets cut down to match. Good luck!
Originally Posted by drolds72
(Post 11850146)
Agree with droids. The tire has a hole in it. It does not meet CPO spec and is currently "unsafe to drive". You need to let the dealer know about it. Bring the documentation from BJ's if necessary. Should be end of story. You need to replace at minimum two tires because of SH-AWD.
(Post 11850362)
(Post 11850362)
I can get a set of new Take off tires for $600.00 If this a good deal?
http://cgi.ebay.com/ebaymotors/4-245...s#ht_538wt_930 |
Originally Posted by Mr.Tea
(Post 11850583)
Rob I have a question, If I replace all four tires should i stick with the OEM tires?
As far as whether the takeoffs are a good deal....I'd feel better inspecting them personally first, but $600 is a decent deal. Not a fabulous deal.....when I sold my RL I sold my stock wheels with stock tires only used for 996 miles to another forum member for $600. In retrospect, that was the deal of the century. :) In your case, the dealer is on the hook here as the car left the dealership with a leaky tire. Ideally, you shouldn't have to put out any money. Do keep us posted. Leaving this thread on the front page for a little longer.... |
Hello Guys I sent the dealer a letter this and got a response from my sales person as follows>> "What do you want us to do about this tire issue? My manager is aware of this issue and was wondering what the solution to this problem would be??
Guys Should I only be asking for a replacement on one tire here? as the problem is only with the driver front? Please advise, i really appreciate. |
(Post 11857476)
Guys Should I only be asking for a replacement on one tire here? as the problem is only with the driver front? Please advise, i really appreciate. "It is best to replace all four tires at the same time. If that is not possible affect your vehicle’s handling."or necessary, replace the two front tires or two rear tires as a pair. Replacing just one tire can seriously It's their problem - they didn't do the appropriate CPO inspection. Stand firm. If they resist, call Acura Client Services and let them handle it. |
Originally Posted by dwboston
(Post 11858697)
Ask for two new replacement tires for the front of the vehicle. From the owner's manual:
(Post 11857476)
(Post 11866788)
Like dwboston said, and I above him, ask for two replacement tires. I guess paying the shipping cost is reasonable, but in an ideal world the dealer would eat that too under CPO. Hope you get this behind you soon so you can enjoy your RL!
Good move, give them a little time to respond. Why not call, or do they usually respond to email promptly?
