Tilt and Telescope
Old Oct 10, 2006 | 02:16 PM
db22's Avatar
Tilt and Telescope
I have heard that Honda products all have a trait of having the steering wheel high in the tilt and if you put the wheel at a confortable angle then you block the view of the guages. I prefer my steering wheel to be at it's lowest position and would even go lower if the RL would allow. The lowest is higher than most cars will allow and most cars don't obstruct the guages so early. Do any of you out there agree or should I go and check another RL - maybe my one is broken?
Old Oct 10, 2006 | 02:30 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
I'm not sure if I'm all the way down, but I'm pretty low and I can see my gauges perfectly.
Old Oct 10, 2006 | 03:31 PM
jftjr's Avatar
'06 RL
Um...doesn't it all depend on the driver's position? I mean, I'm tall in the saddle, have the wheel all the way up, and can see the dash just fine.
Maybe you should adjust your seat height rather than lowering the steering wheel.
Old Oct 10, 2006 | 04:29 PM
i_mobile's Avatar
'06 Celestial/Black
I don't know if it's Honda or what, but that's exactly my same problem. It was in the TL, it is in the RL. And no, I cannot take the seat any lower, it's at the lowest already.
Old Oct 10, 2006 | 10:13 PM
jftjr's Avatar
'06 RL
If you want to be lower relative to the steering wheel, then *raise* your seat....
Old Oct 10, 2006 | 11:13 PM
i_mobile's Avatar
'06 Celestial/Black
Thanks for the condescending advice, but if I raise the seat, then my head bumps on the roof.
Old Oct 11, 2006 | 02:18 AM
Ken1997TL's Avatar
Well how tall are you guys?
Hondas USED to have low dashes and this was never a problem.
Old Oct 11, 2006 | 06:11 AM
db22's Avatar
The driving position should be set for comfort, personal choice and ability to have maximum control of the steering wheel. As is obvious, people come in all shapes and sizes but the ability to see the guages and dash should not be compramised.
Question: If you draw a line perpendicular from the center hub of the steering wheel, is it at the same height as your shoulders, nipples or belly button?
Old Oct 11, 2006 | 02:01 PM
Alpha Geek
I'm 6'8" and I found a perfect position....If I can find one in the RL jsut about anyone can.
Feb 25, 2020 09:57 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
STC
Sep 23, 2015 04:36 PM
gavriil
Jan 4, 2004 12:19 PM
