Symptom of worn wheel hub(NOT wheel bearing)
Good evening Acura lovers
So whats the symptom of a worn wheel hub. I definitely have bad bearings but not sure if I need to replace the hub as well
Passenger side was bad for a year or even more. When I make left turn passenger side makes the scratching noise as if brake dust shield is running against the rotor. Is it really scratching against the rotor? Or this noise is produced In some other way.
Sometimes inner race of the bearing can become lose and actually rub against the wheel hub. See pics to visualize faqed wheel hub in more detail. I want to know if I should spend extra money to replace hubs or take the bearing out inspect hub and then if it turns out to be bad order another hub
Whole assembly will be a lot more expensive. And they only sell entire assembly for rear end. Front is all separate.
I'll take one out in few days will post . 220k miles on the wheel bearing. It's just most people say wheel hub wear is very rare. But happens
I forgot on the FWD stuff like the Odyssey the front hub is all in separate parts. My Camry was like that too. I would honestly just do the hub if the cost is that prohibitive. If the noise is still there, but new assembly and do it all over again in your home garage. Easy.
HEAVY_RL (09-26-2019)
It's 100$ but just hate to waste money if I don't have to . I'll pull everything out and post pics. So people could see For future reference. It's pretty worn . Steering wheel shakes at speeds over 70mph. There is no super loud noise as you can see on YouTubes.
There is a scratching noise when making a left turn. As if brake dust shield is rubbing against the rotor
azatabbasov
05-12-2014 09:03 AM
