Stuck calipers or user error?
I have a 2007 RL that I purchased last summer. Today I attempted to replace the front brake pads.
I was able to compress the two "outboard" pistons fairly easily using the old pad and a pair of pliers. However, the two "inboard" pistons wouldn't budge at all, even when using a c-clamp. Removing the brake fluid reservoir cap and loosening bleeder valve didn't help. I assumed maybe the caliper was stuck, so I moved on to the other front wheel... exact same issue.
So, do I have two bad calipers or am I (hopefully) just doing something wrong / stupid?
I've only done a handful of brake jobs in the past (Honda/Acura), but they have all been straightforward.
Fair question... I assume the inboard pistons are supposed to compress so that they are flush with the caliper housing (same as the outboard pistons). If that's the case, they are definitely not already compressed. Even if I could get the inboard pads out (I can't), there wouldn't be enough room to fit new pads in.
No, still on the rotor. I was only replacing the pads, so I didn't think it was necessary to remove the caliper (following the service manual).
I guess the next step is to pull the caliper and see if I can apply more force to compress the pistons. How much force is too much? Can I damage them?
If you had stuck calipers your car would not drive correctly. You would hear the pads rubbing against the rotor with your foot off the brake, the car would pull one way or the other when driving, and/or your rotors would get extremely hot and likely warp. Put the old pads back in and pump the brakes a few times to see if that unsticks a them. It should not take excessive force to compress the pistons.
I'd remove the calipers & use plenty of brake cleaner under the rubber boot & around the seal. Then try again with your G-clamp. They might give suddenly.
Honda calipers are designed to be rebuild every four years for the Shaken test and they think we are crazy for not doing that. Consequently, they're always bloody seizing.
I pulled the calipers off yesterday. The inboard pads (on both sides of the car) were so bound in the clips that they were preventing me from compressing the inboard pistons. Once the old pads were out, the pistons compressed just fine.
With new pads and rotors, the braking is fantastic.
projektvertx (05-09-2023)
calrow
05-03-2017 10:21 PM
SinCityTLX
55
10-11-2015 01:20 AM
