Speakers not putting out any music?
Hey guys, was wondering if anyone else has experienced this problem?
of the 10 speakers only one was putting out music , the other 9 were not working,
at first it was going both and forth , all working, then back to just one working, but now its only one speaker working the others are not.
if you have experienced this please let me know! thanks?
oviously i'm going to bring back to dealer, but i'm out of warrarnty so i'm sure there going to have to be replaced and that costs lots of $$$.
I doubt you have 9 speakers that are bad. More than likely, it is the balance/fade control electronics in the unit. You can test the speakers individually to confirm.
First I would disconnect battery to reset the unit and try again.
Second I would test the individual speakers.
Finally, if needed, send the unit off yourself. I remember seeing a post where you could send it to the OEM for overhaul at approx. $179. Search electronics portion of the RL forum.
Agreed that speakers would probably not be the problem.
If no kind of work (electrical or other) has been done recently then that would probably eliminate wiring as a cause as well.
That sounds like either a problem with amp or head unit.
Unfortunately that would require testing with known good units, which is something dealers dont kepp in stock.
rockyboy
08-04-2024 10:35 AM
snorf
11-04-2019 06:44 AM
rockyboy
01-25-2016 06:00 PM
ivegotthenav
09-11-2015 07:51 PM
