Speakers not putting out any music?
Hey guys, was wondering if anyone else has experienced this problem?
of the 10 speakers only one was putting out music , the other 9 were not working, at first it was going both and forth , all working, then back to just one working, but now its only one speaker working the others are not. if you have experienced this please let me know! thanks? oviously i'm going to bring back to dealer, but i'm out of warrarnty so i'm sure there going to have to be replaced and that costs lots of $$$. |
No I have not had that problem.
Just out of curiosity, which of the 10 speakers was it? |
sorry, the front left, driver door speaker, the lower one, not the small one by the glass
I doubt you have 9 speakers that are bad. More than likely, it is the balance/fade control electronics in the unit. You can test the speakers individually to confirm.
First I would disconnect battery to reset the unit and try again. Second I would test the individual speakers. Finally, if needed, send the unit off yourself. I remember seeing a post where you could send it to the OEM for overhaul at approx. $179. Search electronics portion of the RL forum. |
ok thanks ill try that, ill disconnect the battery in a little bet and see what happens
Agreed that speakers would probably not be the problem.
If no kind of work (electrical or other) has been done recently then that would probably eliminate wiring as a cause as well. That sounds like either a problem with amp or head unit. Unfortunately that would require testing with known good units, which is something dealers dont kepp in stock. |
