Spark Plug Tube Removal
I replaced my plugs over the weekend (found Bosch in there ) and saw a few things that need attention ASAP.
- Leak in my valve cover that resulted in a small amount of oil on one (front passenger side) of the plugs.
- The valve cover itself is also warped in that area somehow.
- One of the tubes that houses the plug has a chunk missing from it in the top.
We are talking about the same parts and using the same part names. I did forget to add gasket after "leak in valve cover" statement. The gasket and cover are easy to replace, but the tubes are a concern for me. One of my tubes has a peice missing as if it were damaged in the past. When I removed the ignition coil, I could see the chunk missing.
I didnt reference the seal. Yes a chunk is missing from the top of the metal tube in the pic directly above. How that happened is beyond me.
Tinolee (02-10-2022)
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
