SH-AWD Fluid Replacement
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
In reading through the manual, it states that the AWD system in the '05 RL uses Honda ATF, but I couldn't find in there how often it needs to be replaced. Does anyone know? Also, are there any symptoms that I should be looking out for that would indicate that its time for the fluid replacement for the AWD system? Is there a way to check what condition the ATF is in the AWD system via the engine bay?
Thanks!
Thanks!
I replace my rear diff fluid every 30000 miles when I do the trans. whether the MID indictes it or not. I probably over-service my car - I have only had one MID incident appear. I am the kind of owner you would want to buy a used car from.
If you do it yourself, make sure you take the fill plug off first to make sure you can get it off.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
