RL spare on eBay for de-PAXers
First off, this is not my ad. Just throwing this out there for anybody that has de-PAXed and is looking for a spare. These don't come around too often so hop on it if you need one. Buying one new from Acura will put you out over a grand.
http://www.ebay.com/itm/05-06-07-08-...-/261193483673
BDoggPrelude (04-05-2013)
For the most part, it's a vehicle specific application that's produced in low quantities. Look at OEM tires, they're almost always more expensive than aftermarket tires.
ichi d (04-06-2013)
I suppose I figured there would be ten million 17" donuts out there given all of Japanese cars that use them. That just seems absurd and worth searching through every junk yard in America. I know of one in great condition in Austin.
The spare from the 2005-2008 is designed to be used with the flat washer lugnuts that are used on the non-pax RL. The PAX RL uses the acorn lugnuts which will NOT seat properly on that spare. Very important to keep this in mind. It's not really an issue if you already de-paxed with wheels that use the flat washer lugs. But if you are still on the PAX or de-paxed to wheels that don't use the flat washer lugs, then you need to buy and keep 5 of those lugs with the spare.
Hope this helps.
BDoggPrelude (04-07-2013)
Important clarification.... You can use OEM lugnuts or aftermarket lugnuts DESIGNED FOR THE NON-PAX RL.
Hope this helps.
Hope this helps.
LL
HEAVY_RL (04-07-2013)
Hope this helps.
Hope this helps.
adreano17
09-29-2015 08:48 AM
xsilverhawkx
09-28-2015 06:51 PM
