replace hid light on driverside....
Do I have to remove front bumper or can I just take battery out and get my hand in to replace bulb. I do not want to give dealer 300.00 to replace a $30.00 bulb in my 05 rl. Has anyone done it and how hard is it? This is the hid low beam bulb....
HEAVY_RL (09-22-2012)
Hmm - have not heard of replacing through the wheel well. Is it a straight shot that way?
You can do it from the top by removing the battery. Its a mostly blind operation and tight squeeze. Stuff rags under and behind light assembly in case you drop bulb.
Search and you can find lots of threads on this
5 min? C'mon. You couldn't get your jack, lift the car, loosen lugs and remove the wheel in 5 min.
You HAVE to do this procedure on the 350Z. It is a pain in the ass, but mostly because of how tight the back cover of the light assembly was on.
5 mins after having the wheel removed and the pins that hold the plastic covers.
oo7spy (09-23-2012)
Also, if you have to replace one bulb, you might as well do both. Start with the passenger side, as it's the easiest and will give you a good idea of what to expect on the driver's side (since much of it will be by "feel" if you decide to leave the battery connected).
^ Yes, you can remove the battery tie down and slide it about 4" towards the engine without disconnecting any wires.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
