Relay Locations - Radiator Fan and Condenser Fan
2005 Acura RL
I cannot find the location of the relays for the Radiator Fan and the Condenser Fan. I have scoured these forums and the rest of the web. For most similar cars, the TL and the Accord, the relays are easily located in the under hood fuse box. I guess since the RL has so many extra bells and whistles, these relays found a home someplace else - but where? There is nothing in the user manual that addresses any relays at all, just fuses.
For reference I have linked to a photo of my underhood fuse box to show that the relays do not live there.
I am troubleshooting an overheating issue where the fans turn intermittently, slowly, or not at all when the temp gauge starts to rise. I have several other things checked off the list, I need to replace these relays since they are the most likely culprit at the moment. I have tested the fan motors directly and they function properly.
Thanks -
Thanks -
https://www.oemacuraparts.com/v-2005...-engine-room-1
#15 SHOULD be the relay you're looking for. There's an auxiliary relay box with a few relays in it. Look for one in the engine bay that has a cover (#3)
On my 2005, there is a relay bank in the driver side footwell. It does not contain radiator or condenser fan relays. In my manual, the fuse box diagrams are present and the fuses are labeled, but the relays are not labeled, they are left blank. The relay bank that I was made aware of by thoiboi was between the air filter housing and the driver side fender contains a radiator fan relay and it is not mentioned or pictured anywhere in my manual.
If your manual and car are different from mine, that would be odd, but i guess it's within the realm of possibility. Maybe a different model year?
johnny14
08-15-2016 10:39 AM
johnny14
07-24-2016 10:52 AM
Tom N.
04-26-2012 09:57 AM
hdp203
07-25-2007 08:03 PM
