Rear Sunshade works ON/OFF
Old Apr 28, 2014 | 07:56 PM
Mr.Tea's Avatar
Having a bit of an issue with my rear sunshade that keeps working on and off at times and its very annoying.
I have to keep pushing the button multiple times for it to go up! has anyone else had this problem and is there a solution to this?
many thanks.
Old Apr 29, 2014 | 05:38 AM
Frenetic's Avatar
I have the same problem. I sometimes have to hit it multiple times for it to go up. Usually only happens after the car has been parked/off for a while.
Old Apr 30, 2014 | 04:20 AM
06RL/NBP's Avatar
Mine totally stopped working. The mechanic at the agency said to bang on the motor which sometimes is the solution but I am having trouble getting to it.
Old May 2, 2014 | 05:52 PM
Toppatop's Avatar
I had similar issues with mine last year. After pulling most of my hair out, I learned that if the weather is cold less than around 35 degrees or if its really hot, the sunshade will get stuck. although the motor works the fabric is stuck on the base and will not unwind or one side will go up while the other side is stuck. A good cleaning and gentle nudge while pressing the button will help. (obviously this will take two people)
Old May 3, 2014 | 03:56 PM
Alpine9999's Avatar
7th Gear
I wish mine would get stuck in the up position
Old May 3, 2014 | 04:13 PM
IgorMis's Avatar
9th Gear
When you guys say the rear shade gets stuck, can you hear the motor trying to lift it?
Old May 4, 2014 | 07:16 AM
Frenetic's Avatar
In my case, I think it's the button itself that seems to be the issue.
When this intermittent problem occurs, I can press the button and I hear no motor operation at all, the button itself just seems to be unresponsive. However, when the button does seem to work, the shade motor responds and seems to work just fine.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
acurajj
Sep 19, 2015 03:47 PM
08 NBP TL
Sep 8, 2015 08:49 PM
