Rear Seat Removal
Moonwalker
Rear Seat Removal
At some point, I'm going to need to run some power and A/V cables into the trunk. I hope I can get the access I need by only removing the rear seat cushion, and not the seat back.
On other Honda/Acuras, I remember removing couple of bolts between the cushions, and then lifting the bottom out. Has anyone removed the RL's rear seat cushion or back? Any pointers on what needs to be done?
Thanks for any help.
Pull the seat hook knobs (A) while pushing down on the seat cushion (B), to release the hooks (C)
![Name: seat1.jpg
Size: 14.4 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/56333d1501303829-rear-seat-removal-seat1.jpg)
Remove the seat cushion (A), and release the center seat belt buckles (B) from their slits (C).
![Name: seat2.jpg
Size: 20.8 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/56334d1501303829-rear-seat-removal-seat2.jpg)
Release the seat belt (A) from their guides (B).
Remove the rear center seat belt and rear seat belt buckles. note: I usually just pull the center belt all the way out and go around the seat with it.
![Name: seat3.jpg
Size: 7.8 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/56335d1501303829-rear-seat-removal-seat3.jpg)
Remove the bolts from the base of the seat-back (A).
Disconnect the power head restraint connector (B).
![Name: seat4.jpg
Size: 17.0 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/56336d1501303829-rear-seat-removal-seat4.jpg)
Lift the seat-back (A) up to release the wire loops (B) from the hooks (C) on the body, then remove the seat-back.
Install the seat in the reverse order of removal, and note these items:
Guide the belts over the front of the seat-back as you install it.
Before attaching the rear seat-back and cushion, make sure there are no twists or kinks in the seat belts.
When installing the seat cushion, slip the seat belt buckles through the slits in the seat cushion.
![Name: seat1.jpg
![Name: seat2.jpg
![Name: seat3.jpg
![Name: seat4.jpg
![Name: seat5.jpg
Size: 12.2 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/56337d1501303829-rear-seat-removal-seat5.jpg)
Cliffm10 (06-18-2021)
I like your user name. I met the real one the moonwalker at our elementary school of the same name. A cool guy...
I assume you are not one in the same. If you are, you gave my son his "graduation" papers.
rockyboy
08-04-2024 10:35 AM
