Rear center brake light cover
Can you guys tell me how to remove the rear center brake light cover. I need to clean the glass behind it. I tried tugging on it but was afraid of damaging it. I did notice after I did pull on it a little it won't line up right. Will new clips take care of that problem?
Thanks for your help
If I am not mistaken it pulls down - the clips are good at making it stay put. I would assume that new clips will take care of the problem about it not lining up correctly - but, my brake light cover was pulled off by the dealers tint guy - instead of simply replacing the clips, they replaced the entire brake light cover.
office monkey
If it was falling off or something then I would but the way it is now it is trivial...not worth my time going to a dealer to have them replace it assuming it isnt how it is supposed to be.
Yeah, I have the same problem -- I assume the glass is cloudy from all the outgasing of all the plastic from the car being new... I can't get under it to clean it, so I think I might ask the dealer to do it for me when I get the oil changed next...
Randy
Randy
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
wusty23jd
09-24-2015 11:41 AM
