rattle when turning
Old Jul 18, 2011 | 09:45 PM
rhedd's Avatar
rattle when turning
this just recently starting happening. when the steering wheel is half/fully turned (left or right) and I move forward at low speeds, there is a rattle or metallic clinking sound (not a grinding sound). no noises when going straight forward or slight turns for lane changes.
any ideas?
2006 rl
Old Jul 18, 2011 | 09:58 PM
Megatron's Avatar
Bad CV joint or joints?
Old Jul 19, 2011 | 06:42 AM
miner's Avatar
Agree with above. How many miles on your RL?
Old Jul 19, 2011 | 08:42 PM
rhedd's Avatar
136,000km
CV? Hmmm, I read couple of forums that mentioned something along those lines.
Old Jul 19, 2011 | 09:13 PM
white05rl's Avatar
Yes, sounds like a bad CV joint. Have you inspected the CV boots? More than likely, one (or more) has a cracked rubber boot that has allowed the lubricant to escape and caused the failure. You might also notice traces of the lubricant "sprayed" (from centrifugal force) all over the wheel well, etc.
http://www.youtube.com/results?searc...aq=2&oq=bad+cv
Old Jul 30, 2011 | 03:28 PM
mayflowerman's Avatar
On another post this same problem has been associated with a loose hand brake cable that just needs tightening. Do a search on Hand Brake.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
