radio sound and steering wheel help please
Old Feb 4, 2010 | 09:03 AM
jedinyte120's Avatar
hi all,
i recently got into a small accident with the driver front of my car. everything looks great! the problem i have now after the battery was disconnected is that i cant get any sound from my radio. i dont even get any sound when i press the HFL button to sync the phone or the Voice command button.
also, since the minor accident i noticed a slight click when i turn my steering wheel in either direction. it clicks twice when i start from one side turning to the other. it happens at the same interval of each steering wheel rotation. there was also a message indicator for AWD 77.any ideas on both of these issues would be awesome. thanks in advance!!
Roger
Old Feb 4, 2010 | 10:17 AM
robarsan's Avatar
You need to re-enter your radio code to get it working again. I think it's a 4 digit code. If you don't have it, you'll have to take your vehicle to a dealer and they can retrieve it via the radio serial number.
Once the power is disconnected, there are a some systems that need to be re-initiated, the radio being one. You may want to get an owner's manual if you don't already have one. It's all explained in there.
Old Feb 4, 2010 | 07:11 PM
i got the sound to come back via the 30 amp fuse on passenger side. i dont know how the body shop could have blown that fuse.
its the 2nd fuse for the amplifier. now i need help for the clicking.
it clicks a total of 6 times on one complete turn from left to right and vise versa. pretty much every 45 degree turn it clicks,any thoughts?
Old Feb 4, 2010 | 09:14 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Did your airbag deploy? Or was it removed for any of the repairs?
There is a clock spring that enables the airbag to maintain power to the sensors while the steering wheel rotates. This clock spring will cause clicking sounds when it is worn or perhaps damaged by improper airbag assembly removal or replacement.
Old Feb 5, 2010 | 06:19 AM
the airbag never deployed. the click started to happen right after the minor accident. do you think it has anything to do with the AWD 77 message? TIA
Roger
Old Feb 5, 2010 | 10:22 AM
getakey's Avatar
tampa - you amaze with info. Do you disassemble your cars and put them back together
Old Feb 5, 2010 | 12:19 PM
lland's Avatar
The accident could have moved the spring or knocked something into it so it makes the noise you are hearing. The only way to tell is to remove the steering wheel and take a look. Not hard to do as a number of us have to install the "wood" wheel ourselves. Take a look in the RL Garage HERE, page down and follow the wood steering wheel installation insgtructions. I'd imagine the dealer would charge $100 or more to check it out.
LL
Old Feb 5, 2010 | 04:16 PM
Roger
Even if the airbag did not deploy in the accident, you mention the body shop repaired the front end? I expect they removed your airbag before making the repairs as to not falsely deploy the airbag during the repairs. There are sensors under the front fascia that could trigger the airbag.
Perhaps in doing so they damaged the clock spring.
Old Feb 7, 2010 | 09:48 AM
Tampa,
thanks for your input. i understand what you mean,but the click was already there before i took the car to the body shop. im dropping the car off at the dealer on monday,i also told the dealer about the AWD77 message and they wanted me to drop it off ASAP.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
PortlandRL
Sep 14, 2015 12:01 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
