P2R install and impressions
Old Jan 28, 2009 | 11:56 PM
470hpGS400's Avatar
Smile P2R install and impressions
Super fast shipping from Excelerate. Thanks Joshua.
Install is a PITA though as Acura decided to overly complicate something as simple as a air filter housing and boot removal (tight). This get very tight after the install as the air intake tube must be compressed a bit to fit due to the reduced room available. Keep in mind that the gaskets are separate and come in single packs x2.
Reset the ECU.
Drove around a bit, not really expecting much as cars generally seem snappier right after an ECU reset.
After some miles the car does seem to exhibit a little more oomph. Certainly not significant or close to what the pulley offers-I believe dynos from others indicated 5hp or so from this mod. Will post back with further impressions as the miles pile on.
I will install the AEM V2 intake later on as I need to cut it to fit.
Old Jan 29, 2009 | 12:11 AM
fatty's Avatar
Can i get some more pics of the oem filter box and engine compartment?? Want to see how snug its getting.
Old Jan 30, 2009 | 10:01 PM
Excelerate's Avatar
Former Sponsor
Thank you and you're welcome.
Gains on the TL showed about 5whp. It's not going to be a huge seat of the pants gain but every little bit helps and it help reduces intake air temps and for just over $100 it's a great mod.
Old Feb 1, 2009 | 01:02 AM
470hpGS400's Avatar
Will do this weekend, been busy.
Old Feb 1, 2009 | 09:01 AM
Blazing GT's Avatar
In the TL forums, I used to see guys having their intakes snap when using the P2R + Intake.
Old Feb 1, 2009 | 10:38 AM
470hpGS400's Avatar
That is because of improper installation. The original intake mount points were being used and caused the mount to snap. Easily remedied.
Old Feb 1, 2009 | 11:41 AM
plastikman's Avatar
How long did the install take you to do ?
Old Feb 1, 2009 | 10:19 PM
470hpGS400's Avatar
About 30 minutes or so. 4 bolts, air filter housing removal, getting it all back together,etc.
Just the tight fit makes things difficult.
Old Feb 1, 2009 | 10:35 PM
fatty's Avatar
pix!
Old Feb 1, 2009 | 10:49 PM
470hpGS400's Avatar
pix!
Getting there, I swear. I spent this evening swapping out the field coil in my AC compressor.
Old Feb 8, 2009 | 10:12 PM
fatty's Avatar
Which method did you use to reset the ecu?
Old Feb 9, 2009 | 07:45 AM
fredren's Avatar
unofficial HONDA rep
Reset the ECU.
i would say 5whp on a tl, but on an RL hmm myabe even less when you take in consideration the AWD
Old Feb 9, 2009 | 07:53 AM
470hpGS400's Avatar
Your correct, it is well established that AWD exhibits more drivetrain loss.
Fatty, I just disconnected the negative terminals for 20 minutes.
Old Feb 9, 2009 | 08:11 AM
Ballinger's Avatar
I want to hear your impressions regarding the power, but I also want to see how much you've got to modify in order to fit your AEM kit.
Old Feb 11, 2009 | 08:35 PM
NSKRedLine's Avatar
5th Gear
Yeah I'd like to see how you modded the spacer to keep it from snapping too
Looks great though!
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
ryanfett
Oct 29, 2015 06:01 AM
TxRzrBk
Sep 17, 2015 01:07 PM
obert
Sep 3, 2015 08:40 PM
