No Heat! Help!
Old Mar 9, 2015 | 11:11 PM
01Bblack's Avatar
9th Gear
No Heat! Help!
Hey All,
About to pull the trigger on a 2005 RL. Car is decent with good service history- deal is solid. For some odd reason the car has no heat or A/C. No leaks around the water pump and the car has adequate coolant that tests out to -60 Driving the car this past weekend for about 30 minutes - no issue with overheating and the car does blow air.... just lukewarm regardless of setting. Any insight into this?
Thanks!
Old Mar 10, 2015 | 07:22 AM
BDoggPrelude's Avatar
It is a known issue with the 05 and some 06 RL's. My advice, keep looking around and try to find an 07+ model.
Old Mar 10, 2015 | 08:31 AM
HEAVY_RL's Avatar
whats the $$ number? and can you turn a wrench?
Old Mar 10, 2015 | 09:22 AM
01Bblack's Avatar
9th Gear
The number is very good on the car.... almost a give-away
I am far from a mechanic, however, I like to thank that I am decent with a wrench. What is the worst case scenario? Any ideas?
- C
Old Mar 10, 2015 | 11:00 AM
HEAVY_RL's Avatar
well... those two systems only meet in a few ways.
So I think you may have two issues...
To start you would want to through trouble shooting steps.
Does the fan in the front of the car and in the dash work?
Is the thermostat good?
Are the climate controls functioning?
Is the A/C clutch working?
The worst case would be a burned up compressor and metal in the system, that could lead to a FULL replacement which is expensive.
Best case would be a recharge of the A/C system and a thermostat.
Smart money would be to buy it and get an extended warranty, then file a claim.
Old Mar 10, 2015 | 03:33 PM
oo7spy's Avatar
The problem with the heater and A/C not working is you don't know if it is the common components just before the vent or individual parts from each system. Take it to an HVAC shop and have it diagnosed.
Old Mar 11, 2015 | 12:01 AM
01Bblack's Avatar
9th Gear
Does the fan in the front of the car and in the dash work? Fan in the car blows air (feels like outside air)
Is the thermostat good? Not leaking?!
Are the climate controls functioning? Climate controls are functioning as well as those within the navigation system
Is the A/C clutch working? Not sure.... Didn't hear it engage... reminds me of my 2004 TL in which near the end the engagement was sporadic
Any DIY on this Stator? I have been looking deeper and I suspect that this may be the issue
Old Mar 11, 2015 | 08:08 AM
HEAVY_RL's Avatar
I think you might be on to the right path...
Old Mar 11, 2015 | 09:02 AM
oo7spy's Avatar
The stator is a very common issue with 2005 & 2006, but would that affect the heat?
Old May 3, 2015 | 03:51 PM
01Bblack's Avatar
9th Gear
UPDATE -
Spent some time tinkering with the car today.
The air does in fact blow - fan speed changes throughout the 7(or so) speeds with no issue. When clicking AC on/AC off there is no "click" or sound of an engaging compressor. ALSO in the diag menu there are no fasults for A/c. Hmm
Seems odd - am I on the right path that the compressor would need to be replaced OR should I check a fuse first?
Thanks all!
Old May 4, 2015 | 09:41 AM
oo7spy's Avatar
You can check the compressor by applying 12V directly to the power connection. If it kicks on, it's probably your stator. If it doesn't, it's probably your compressor.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
