NEW MEMBER..... 05 acura rl dual vent temp. problem
hello everyone i am a new member but not new to the site ive used this site for answers and research for years for a tl i used to have now i am a proud owner of a 05 acura rl and love it. i am a mechanic and i do it for a living so i never really ask on how to i just find the problem and fix it but i hit a locked door om this one i cant figure out wtf is going on anymore this is how everything started.....
found out my water pump was leaking one sunday morning and decided to try to stop it a little by putting half a bottle of stop leak in it. after i did i let it run in my garage for around 45 minutes with the heater on blast turned it off went inside and came back out to go out about 2 hours later and noticed as i was driving that the driver side air was not getting hot but the passenger side is working perfectly fine ive been up and down checking everything no dtc's checked all the ambient sensors checked motors did the system check with snap on scanner done it checked it all and still cant figure it out!! looked everywhere oddesy forum on this forum everywhere i figured its time to post it up myself see what i get so please i f anyone can help me out i will really appreciate it i want to start modding the car but first gotta fix these things.
car has 177k miles new water pump new timing belt and no dtcs car drives perfect everything works except no heat drivers side.
anything is well appreciated thank you!!
That's is one (or two) long thought(s).
Does the A/C blow evenly on both sides? Leave the car on Auto LO for a bit and confirm both sides of the dash are blowing around the same temp. Are you sure it was working before the way you are testing it now?
yes it was working fine when I got the car and yes if I lower it to low they both throw out good cold A/C its like if its stuck on cold
oo7spy (12-16-2013)
yeah but I already checked all four power probe them and everything plus if one was bad it would throw a code and maybe the door if physically broken or stuck but idk how to check that besides removing the dash
You don't have to remove the dash to get any of them out. And they won't necessarily throw a code as long as the circuit is complete. It could be physically stuck on the cool position. You could take it loose and confirm it's movement while adjusting the temp.
Period.
What was it?
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
