MICU replacement questions
Old Sep 6, 2021 | 09:29 AM
tvarghese's Avatar
Question MICU replacement questions
Hello,
Been tracking down a battery drain issue in my 2005 Acura RL and I have isolated it to Fuse 7 on the Drivers side fuse box.
Best as I can tell (page 22-195 in service manual) that goes to:
- Fog Light Relay
- Combination Switch Control Unit
- MICU
Of the three the MICU seems like the most likely candidate due to complexity more than anything else.
Questions:
1) First of all, is the MICU the box that is part of the driver's side fuse box?
2) I've read about replacing one on the TL and it seemed like a PIA, but straightforward. Same on RL? Do i need to take it to a dealer for programming?
Was going to buy a used one on ebay. Don't see any for sale on the various sites I searched. From what I understand that is what controls the locks and such and is on all the time,
https://www.ebay.com/itm/26455304074...EAAOSw1MNd5CDF
The Combination Switch Control Unit has CAN, so it is somewhat intelligent but not anywhere as complex.
Thanks!
Old Sep 14, 2021 | 02:23 AM
Nomgle's Avatar
Do you have keyless entry on your RL ? There is a known issue with the door handles shorting, they can get warm and slowly drain the battery. It makes sense that this draw would be coming from the MICU.
Threads like this one https://acurazine.com/forums/second-...g-long-711420/ might be helpful !
Old Oct 9, 2021 | 06:09 AM
tvarghese's Avatar
I do have keyless entry and it appears to be working fine. I bought an MICU box off ebay, will install it sometime when my daughter comes home in the next couple of months. In the meantime she just disconnects the fuse in the fuse box when she won't be driving the car for a while. If that does not fix it, then we will have to dig further.
Thanks for your response and sorry for the late reply.
Old Nov 13, 2021 | 07:42 PM
tvarghese's Avatar
Well, my daughter came back for the weekend and decided to attempt the MICU swap.
After about 6 hours gave up on it. Could not figure out how to remove the connectors on the rear of the unit. The problem is that something went wrong and the MICU is no longer functioning
The current consumption dropped down to 120mA, but the car won't start...
Oh well, time to take it in and see if they can fix it.
tvarghese
Nov 4, 2022 08:01 AM
6for2
Sep 18, 2021 12:57 PM
boybeasy
Feb 21, 2013 08:10 AM
sophiestl
Jun 10, 2011 10:37 AM
