key fob, door locks and nav dead
Old Aug 5, 2011 | 01:57 PM
jgcummings's Avatar
3rd Gear
I have a 2005 rl, my key fob isn't communicating with my car, had to use key, to unlock and start car, power doors locks don't work and nav won't do anything, if my sensor is broke in my door handle would it cause this? I called acura, thats about 2 hours away and said they would just have to check it, $110 an hour, & I should plan on leaving it all day!!!
Old Aug 5, 2011 | 02:37 PM
getakey's Avatar
Does your radio work?
Old Aug 5, 2011 | 06:06 PM
037's Avatar
037
I would check fuses before taking the car anywhere just in case.
Old Aug 6, 2011 | 09:02 AM
HEAVY_RL's Avatar
I hope its not the dreaded dead handle symptoms.
Can you start and drive the car with the key?
Old Aug 12, 2011 | 04:26 PM
jgcummings's Avatar
3rd Gear
Yes my radio works fine, to unplug my door handle sensors do I remove the handle or do it from the inside by removing the door panel?
Old Aug 13, 2011 | 09:31 AM
jgcummings's Avatar
3rd Gear
I have to use the key to unlock the doors and start the car
Old Aug 13, 2011 | 10:48 AM
oo7spy's Avatar
There is a service manual in the garage that will tell you how to disassemble.
Old Aug 14, 2011 | 12:46 AM
insanevtec's Avatar
I would take it to a local auto zone or similar auto parts store and have them test your battery and if they have the equipment, test your charging system also. They should do it for free I know the ones close to me do
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
kixo
Sep 25, 2015 03:07 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
